BT Vectoring Trials
- BT Vectoring Trials
Re: BT Vectoring Trials
21-01-2015 8:33 PM
You can check the band plan, ECI cabs have a longer band plan. My ECI goes to 4083 at the end.
Or a command will list the dslam chipset.
> xdslctl info --vendor
xdslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 31615 Kbps, Downstream rate = 72641 Kbps
Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 72916 Kbps
ChipSet Vendor Id: IFTN:0xb204
ChipSet VersionNumber: 0xb204
ChipSet SerialNumber: 5501843597
IFTN = ECI
Huawai should show as broadcom which I think will be BDCM.
21-01-2015 8:46 PM
Quote from: 11110_110 How do we know what cab has which ?
Or I can tell you.
21-01-2015 9:13 PM
Cheers for looking Andy.
21-01-2015 9:24 PM
21-01-2015 9:26 PM
@ 11110_110
Looking at your speed test results your upload seems very low compared to the download http://www.thinkbroadband.com/guide/fibre-broadband.html indicates that it should be 35/14
Is there any reason for that as far as you know
21-01-2015 9:31 PM
You'd be unlucky to get an ECI cabinet, statistically speaking.
21-01-2015 9:35 PM
21-01-2015 9:37 PM
That is also how far I am as well
21-01-2015 9:52 PM
In all honesty, we have come to the conclusion that the speed we have is more than enough, we don't do big downloads etc just mostly streaming.
The best I've seen banded around here is about 9 UP for our sort of distance.
21-01-2015 9:56 PM
My estimate is up to 3Mbps although I get nearer 3.5Mbps on speed tests
21-01-2015 10:06 PM
21-01-2015 10:44 PM
Aren't ECI cabs black and the Huawei ones green? Or is that too much of a generalisation?
Also I thought modems were given to match the cab type?
22-01-2015 1:23 AM
22-01-2015 1:04 PM
looks like a Huawei 288 FTTC
Quote from: AndyH You can figure out whether it will be ECI/Huawei from how it looks - http://www.kitz.co.uk/adsl/fttc-cabinets.htm#fttc_street_cabinet
22-01-2015 1:50 PM
