BT Vectoring Trials
- BT Vectoring Trials
Re: BT Vectoring Trials
18-08-2014 7:03 AM
Link does'nt work
Quote from: Melancholie Update from ISPReview here.
For those hoping for this to arrive in a hurry not good news, and not especially encouraging as far as node level goes.
18-08-2014 10:03 AM
I know, I know, FTTP would have been way more expensive but in the long run I wonder if it wouldn't have worked out cheaper...
Oh, well...
18-08-2014 11:40 AM
When an errored superframe hits the modem it requests that the DSLAM retransmit that superframe. There will be some jitter caused by the retransmission.
Ask Sky customers how they've found it, they've had G.inp running for a while.
18-08-2014 11:41 AM
Link works fine, check your kit.
18-08-2014 11:43 AM
Quote from: acarneiro I know, I know, FTTP would have been way more expensive but in the long run I wonder if it wouldn't have worked out cheaper...
Yes it would've been cheaper in cash terms, however set that against the lost income from FTTC, and the interest payments on the borrowing BT would've done.
Trust me if it had been cheaper BT would've done it that way, the only thing they're happy to overspend on is football.
18-08-2014 11:45 AM
On Fibre? If so, would I be right in thinking (theoretically) you could get a higher sync on the same line with Sky than you would say, Plusnet / BT retail?
18-08-2014 11:48 AM
18-08-2014 11:52 AM
18-08-2014 11:57 AM
As Chris Pettitt said previously, there are some planned changes with regards to those profiles and Openreach invited CPs to put forward what they want (as many as 25 profiles I believe).
With retransmission, they were looking on a larger scale whether the reduction of the errors and the recovery of the line rate justified the the expense/business case of developing it nationwide.
I think the idea is that Openreach will build and develop the profiles and then sell them back to the CPs.
18-08-2014 11:59 AM
21-01-2015 7:56 PM
A person who works for openreach has indicated things arent looking good for ECI on a public forum. It doesnt mean there is going to be no ECI rollout but just he hasnt seen any ECI activity its all Huawei.
Given openreach's silence on ECI questions, and the fact they ceased ECI rollout when they started vectoring trials, I am personally not surprised if this is the case, but worryingly this will create a two tier service with it been a postcode lottery if you get vectoring or not.
Also this thread needs moving to the FTTC section not ADSL.
21-01-2015 8:02 PM
Quote from: chrcoluk the fact they ceased ECI rollout when they started vectoring trials
They are still installing ECI cabinets.
21-01-2015 8:04 PM
21-01-2015 8:13 PM
21-01-2015 8:29 PM
