BT Smart Hub / Home hub 6
- BT Smart Hub / Home hub 6
29-05-2018 7:12 PM
Planning on changing from BT to PlusNet keeping my smart hub/home hub 6. Obviously reset, change username and enter password to get it to work.
What about the other networks, as BT is with fon, I currently have the following networks on my router:
- My Network BTHub6-XXX
- BTWifi-with-Fon
- BTWifi-X
Do I need to turn off the other BTWifi networks manually or is it automatic, will it carry on broadcasting as it will take up bandwidth. Can I sign up with Fon and use them - have any PlusNet users done this?
Re: BT Smart Hub / Home hub 6
29-05-2018 7:17 PM
As this is an open forum to view, if you are having set-up issues, look at post 41 from @LifeonMars https://community.plus.net/t5/Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1415464#41
29-05-2018 8:18 PM
