BT Openreach Modem for new Property
supersub70
I've just moved to a new house and taken the opportunity to change my Standard Broadband to a Fibre Package. I've received my new PlusNet Router but do I also need a white BT Openreach Fibre Modem? I remember seeing one when I viewed the property however the sellers have taken it with them. We have one on the end of our line at work too, so I'm concerned PlusNet have assumed I already have one at the new property and the new PlusNet Router will not work without it.
SpendLessTime
Aspiring Hero
Fixes: 67
Re: BT Openreach Modem for new Property
If you have the Plusnet Hub One then you do not need a modem as it is an all in one device (combined modem and router)
If you look at the support page, is your device shown https://www.plus.net/help/broadband/router-user-guides/ and if so which one?
Browni
Aspiring Hero
Fixes: 45
The new Plusnet routers have have an inbuilt modem.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
agedgopher
If you have the newer Hub 1 then it does not need the Openreach box. It will work well without.
supersub70
Thanks I have a HUB type so no worries.
