BT Line Fault Report
Trebor12345
I have had a line fault which BT is saying is now clear.  The report below was provided.  Does this show that my line is now good quality?
KBD
GEA Test Detail
Circuit ID NA Service ID BBEU22047951
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 36.1 Mbps
Upstream Speed 10.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 382.0
Upstream Rate Assessment Very Good
Technology VDSL
DP Type External
Profile Name 0.128M-55M Downstream 6dB, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2020-04-28T17:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 36.1 Mbps 54.9 Mbps 54.9 Mbps
Up Stream Line Rate 9.9 Mbps 9.9 Mbps 9.9 Mbps
Up Time 816.0 Sec 900.0 Sec 899.8 Sec
Retrains 0.0 2.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2020-05-08T17:48:24.741+01:00 2020-05-08T18:03:24.741+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
WP Profile CLT TAM NIC ODC
50400 Pass N/A N/A N/A
Radius
Engineer Notes
Your Minimum Guaranteed Speed: 30.9Mb
Engineer has resolved the fault located at the D-side including aerial cables / lead-in / block terminal.There was a fault outside the end customer's curtilage caused by general wear and tear.The fault was fixed by clearing in joint. Additional information: Engineer has not visited end customer premises. Final alternate test results: xDSL test performed at the modem.xDSL test indicated line was OK on 28/04/2020.Final FastTest completed.The test passed on 28/04/2020 16:48.
7 REPLIES 7
RichardB
Seasoned Champion
Fixes: 39
Re: BT Line Fault Report
To help understand what the BT Openreach line to your property can support, please use:
http://dslcheckercat.bt.com/
And post the result but blank out or crop your phone number.
Trebor12345
Thank you.
Cabinet 4
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 80 58.3 20 19 52.9 Available Available --
VDSL Range B (Impacted) 79.2 55 20 17.9 48.3 Available Available --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 5 -- 3 to 7.5 Available -- --
WBC ADSL 2+ Annex M Up to 5 Up to 1 3 to 7.5 Available -- --
ADSL Max Up to 2 -- 1 to 3 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
Observed Speeds
VDSL
Max Observed Downstream Speed (Mbps) 74.86
Max Upstream Observed Speed (Mbps) 20
Observed Date 2020-04-29
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 08-04-2020
FTTP is not available.
RichardB
Seasoned Champion
Fixes: 39
The VDSL observed speeds on 29/4/2020 look good for Plusnet Fibre Extra [max speeds 80 / 20 mbps] dependent on BT line quality and length :
The GEA test looks like you are on Plusnet Fibre [ maximum speeds 40 / 10 mbps or 55 /10 for some legacy contracts]:
Did you move from PN Fibre to Fibre extra? The GEA test results have previously been observed to be laggy / outdated.
If you can see the Fibre modem line stats, what do they report?
Regards
Richard
Trebor12345
All beyond me, a little.
Did you move from PN Fibre to Fibre extra?  As far as I am aware I am just on the stardard fibre package (40 meg max)
The GEA test results have previously been observed to be laggy / outdated.  What does this mean?
If you can see the Fibre modem line stats, what do they report?  How do I do this?  Interrogate the router, if so where abouts?
Trebor12345
Hi
If you can see the Fibre modem line stats, what do they report?   I found these results from the router, do they indicate any thing?
8. Noise margin: 16.1 / 16.4
9. Line attenuation: 16.4 / 16.6
10. Signal attenuation: 16.3 / 16.6
Fixes: 419
@Trebor12345
I think that you need to go back to the beginning. Why the question?
Are you having a problem? How are you measuring download speed, are you connecting a computer to yout hub using an Ethernet cable? These are the only tests that count when testing the DSL connection speed.
From the results above it should be 40-50 Mbps. If it's less have you tried using the test socket? To access this you take the front off the BT master socket, you may need to remove two screws, and plug a filter into the socket that you will find in the box.
Trebor12345
I am having voip problems when working from home.  I will try the socket and filter test.
