BT Home Hub 5
tancred2026
BT Home Hub 5
Hi there, Just had Plusnet fibre installed and am left with an Openreach modem and Plusnet router, and all the wires that go with them, in the front room (this is where the incoming phone socket is). I understand that the HH5 is compatible with Plusnet and installing it will make a cleaner installation. Has anybody done this ?
davenos
Re: BT Home Hub 5
I use a home hub 5 and its really easy to set up.
The username is your forum username @plusdsl.net and the password is the one you use to login to the plus net site.
Or here is a full guide from one of the forum users http://community.plus.net/forum/index.php/topic,113872.0.html
gofaster
Re: BT Home Hub 5
Check that it is a HomeHub 5B. The 5A suffers from G.INP disease. (See other threads about G.INP)
Razorback
Re: BT Home Hub 5
Remember to do a full factory reset to get rid of the BT set up.
NorthEasterner
Re: BT Home Hub 5
What's G. INP disease?  Roll eyes
Sorry, I haven't been on for quite a well due to busy life at home
NE
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 6
Re: BT Home Hub 5
jamesanstee
Re: BT Home Hub 5
BT don't seem to be in much of a hurry to release new firmware to fix the G-INP issue either . And HH5 Type B seem hard to get hold of.
Fixes: 6
Re: BT Home Hub 5
Quote from: jamesanstee
The talktalk super router (hg635) could be a alternative. Last time I looked there was plenty on the auction site.
Kitz is reporting it as G.INP ready
Some details here: http://npr.me.uk/hg635.html
