BT Home Hub 2
FIXED- Subscribe to RSS Feed
- BT Home Hub 2
19-02-2021 12:55 PM
Hi
I am intending to upgrade my Plusnet router to a BT Home Hub 2, and was planning to buy one on eBay.
However I am confused about whether there are different Home Hub 2 routers for ADSL and Fibre? And if so, how do I tell the difference?
Realise this may be a bit of a noob question but thought it was better to ask before buying 😀
Fixed! Go to the fix.
Re: BT Home Hub 2
19-02-2021 1:16 PM
Welcome to the forums, @Groucho . The BT Home Hub 2 aka HH6 is dual ADSL/VDSL - the only variants are the Home or Business, the difference between the two being that the Business version is a little more configurable.
Re: BT Home Hub 2
19-02-2021 1:17 PM
@Groucho Welcome to the forum.
I sincerely hope that you are referring to a Smarthub 2 and not the ancient Home Hub 2?
All Smarthubs work on both ADSL and fibre.
Why are you going for the more expensive Smarthub 2? These are only better than the Smarthub 6 if you have a matching satellite mesh unit. Their downside is that you can’t split the 2.4 and 5GHz bands.
Alternatively consider a Business Smarthub 6 and get the additional setting options.
Settings for either. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
Re: BT Home Hub 2
19-02-2021 1:47 PM
Re: BT Home Hub 2
19-02-2021 2:44 PM
Thanks - so why is this router being described as ADSL?
19-02-2021 2:48 PM
Because that IS an ancient Home Hub 2 NOT a Smart Hub 2. Its not suitable for Fibre
Re: BT Home Hub 2
19-02-2021 2:48 PM - edited 19-02-2021 2:50 PM
Looking at that listing, @Groucho - because it is the 'ancient' Hub2 referenced by @Baldrick1 , and not the SmartHub 2.
Edit @MisterW beat me to it.😉
Re: BT Home Hub 2
19-02-2021 3:10 PM - edited 19-02-2021 3:11 PM
Thanks (and @jab1) - you have now cleared up my confusion.
I think this particular listing was also being deliberately vague in its opening description.
Re: BT Home Hub 2
19-02-2021 3:33 PM
Rather than deliberately vague I would call it definitely if not deliberately misleading!
Some care is needed. I have also seen HH5s described as Smarthubs.
