BT Home Hub 2
Groucho
BT Home Hub 2
Hi
I am intending to upgrade my Plusnet router to a BT Home Hub 2, and was planning to buy one on eBay.
However I am confused about whether there are different Home Hub 2 routers for ADSL and Fibre? And if so, how do I tell the difference?
Realise this may be a bit of a noob question but thought it was better to ask before buying 😀
8 REPLIES 8
Legend
Fixes: 255
Re: BT Home Hub 2
Welcome to the forums, @Groucho . The BT Home Hub 2 aka HH6 is dual ADSL/VDSL - the only variants are the Home or Business, the difference between the two being that the Business version is a little more configurable.
Fixes: 419
Re: BT Home Hub 2
@Groucho  Welcome to the forum.
I sincerely hope that you are referring to a Smarthub 2 and not the ancient Home Hub 2?
All Smarthubs work on both ADSL and fibre.
Why are you going for the more expensive Smarthub 2? These are only better than  the Smarthub 6 if you have a matching satellite mesh unit. Their downside is that you can’t split the 2.4 and 5GHz bands.
Alternatively consider a Business Smarthub 6 and get the additional setting options.
Settings for either. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
Legend
Fixes: 255
Re: BT Home Hub 2
Thanks for the clarification/advice @Baldrick1
(Note to self: stay off the Router board)😉
Groucho
Re: BT Home Hub 2
Thanks - so why is this router being described as ADSL?
Fixes: 395
Re: BT Home Hub 2
Because that IS an ancient Home Hub 2 NOT a Smart Hub 2. Its not suitable for Fibre
Legend
Fixes: 255
Re: BT Home Hub 2
Looking at that listing, @Groucho  - because it is the 'ancient' Hub2 referenced by @Baldrick1 , and not the SmartHub 2.
Edit @MisterW  beat me to it.😉
Groucho
Re: BT Home Hub 2
Thanks (and @jab1) - you have now cleared up my confusion.
I think this particular listing was also being deliberately vague in its opening description.
Fixes: 419
Re: BT Home Hub 2
Rather than deliberately vague I would call it definitely if not deliberately misleading!
Some care is needed. I have also seen HH5s described as Smarthubs.
