BT HH5 (Type B)
- BT HH5 (Type B)
BT HH5 (Type B)
06-03-2015 4:27 PM
Hi
Everything has gone smoothly relative to activation and simple details change on the router.
What I am concerned about , even though I have left BT the BT WIFI/FON still seems to be broadcasting, I am at complete loss as to disabling it. Naturally I would expect an issue like this would be against T&Cs on plusnet. Basically I am wondering what I need to do to disable the WIFI/FON function?
I have tried speaking to BT and it falls on deaf ears, everyone telling me to go to MyBT which doesn't make a damn difference.
Does anyone know of a way to contact someone at BT who may have a clue whats happening and how to fix it?
Message 1 of 3
(749 Views)
2 REPLIES 2
Re: BT HH5 (Type B)
06-03-2015 5:45 PM
I think if you perform a factory reset it disables the FON part
Message 2 of 3
(337 Views)
Re: BT HH5 (Type B)
06-03-2015 6:15 PM
Quote from: launton I think if you perform a factory reset it disables the FON part
I hadn't thought of that, however thanks to your suggestion it has removed FON.
Thank you
Message 3 of 3
(337 Views)
