BT Broadband Availability Checker
grexy
May be a stupid question but I get a VDSL range A (clean) downstream rate of 19.5 on the checker.
my openreach ip profile is 19.42 and I stay connected at 19+ plus for weeks at a time, and it's very stable and no issues.
beacuse the checker say 19.5, does that mean I'll never get any faster and my ip profile will never be increased?
Moderator's note by Adie (Dvorak) All caps title removed as per Forum rules
Fixes: 171
Re: BT Broadband Availability Checker
dslchecker provides estimates for the line.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 19.5 13.1 2 0.9 -- Available -- --
Although it doesn't mean that your line will 100% never provide higher speeds than the estimate that is shown, we would expect your line to perform somewhere within the speed range estimate that is shown.
From the sounds of things, your line is performing pretty well being at the top end of the estimate.
 Harry Beesley
grexy
Thanks, I'm not having issues, but just wondered if my openreach ip profile would every change to allow me to even try and get anything faster. I'm guessing everything looks good and within the estimate, so not much chance of it changing unless something goes wrong.
Fixes: 171
Although technically it's possible for it to increase, it's unfortunately not something we can guarantee.
 Harry Beesley
