BT Broadband 67Mb Minimum speed guarantee*
davidtrex
Quick question (I know there are things which impact BB speed and apologises as I have been a vigin media customer for years (was getting a solid 200Mb with virgin before I moved) so this is pretty new to me)
but BT Broadband are saying I should get at least 67Mb
My current and steady speed is about 20Mb down and 8Mb up - is there a reason why BT will say I will get those speeds yet I am not getting them with plus.net?
Edit: According to the BT Speed test
Download speed achieved during the test was - 20.34 Mbps
 For your connection, the acceptable range of speeds is 14.7 Mbps-21 Mbps .
 Additional Information:
 IP Profile for your line is - 21 Mbps
petelane1951
Re: BT Broadband 67Mb Minimum speed guarantee*
I have raised the same question because my neighbour has a guaranteed speed of 52 Mbps from BT on their Infinity 1 package. However we can only get 11 Mbps at present which is why my neighbour moved to BT Retail. Both our lines had the same speed when my neighbour was with Plusnet.
The good news is that HarryB from Plusnet is pursuing our issue and it appears to be due to BT Openreach and their fibre rollout in our village.  Dorset Superfast Broadband team were advised that our village was completed even though the nearest cabinet to us was not fully installed and configured. My neighbour joined BT who guaranteed a high speed and they appear to have got Openreach to resolve his issue.
rongtw
Fixes: 11
@davidtrex possibly you profile has been incorrectly set by PN Sad  i hope we see some Staff soon who can check this for you
@Gandalf
Fixes: 230
Hi there @davidtrex
Sorry to hear you're having speed issues.
 It's not a profile issue. The router is in sync at a slow speed...
Sync Status In Sync
Downstream Speed 21.7 Mbps
Upstream Speed 10.3 Mbps
Broadband tests are indicating a possible line fault...
Voice Line Test Result Voice fault suspected - contact Voice CP to progress copper issue
A line test is pointing towards an external fault which I've now raised with Openreach. We've been given an estimated response time of by 01/06/17 23:59:59. Hopefully it's a quick fix.
davidtrex
Thanks for looking into this for me and starting the ball rolling. Had the emails about it being investigated.
