BQM showing a sign of plusnet gateway issues
goldenfibre
Seasoned Pro
Fixes: 12
There is big reduced speed in broadband with latest BQM has largest packet loss and increasing higher latency since 8pm.
Is there fault on BT network, exchange or gateway?
BQM live: https://www.thinkbroadband.com/broadband/monitoring/quality/share/93823add03e573fe5a69d3e86afebfa363...
TBB Speedtest: https://www.thinkbroadband.com/speedtest/1601580929352507855
5 REPLIES 5
RichardB
Aspiring Champion
Fixes: 27
Re: BQM showing a sign of plusnet gateway issues
Plusnet issue  I would guess?
Another two customers affected here:
https://community.plus.net/t5/custom/page/page-id/_PingGraphs
See graphs titled Oliver & rpm.
goldenfibre
Seasoned Pro
Fixes: 12
Yep, it affect me, my parents, oliver, rpm and townman in this latest BQM graphs
Pity my graph isn't there!
Does changing to different gateway solve this?
RichardB
Aspiring Champion
Fixes: 27
Worth the minimal effort of dropping the PPPoE and reconnecting, to see if you can land on a different gateway.
If the issue is in regional backhaul between your PoP area and Plusnets data centres then it will not work.
Bud
goldenfibre
Seasoned Pro
Fixes: 12
Just done this: Worth the minimal effort of dropping the PPPoE and reconnecting, to see if you can land on a different gateway.
https://www.thinkbroadband.com/speedtest/1601583415519351555 speed are much better now but not perfect yet
BQM showing improvement of changed to different gateway
BQM after different gatewayBQM after different gateway
