BNG :(
- BNG :(
Re: BNG :(
16-08-2015 5:58 PM
Re: BNG :(
16-08-2015 5:59 PM
All test WIRED !!! looks like another Hop is ion order
Re: BNG :(
16-08-2015 6:01 PM
These website based pings can be misleading.
Re: BNG :(
16-08-2015 6:03 PM
TBH honest andyH am getting sick of testing tracerts , pings , to show PN there is a problem at peak times
now on ptw-bng01
Re: BNG :(
16-08-2015 6:12 PM
Re: BNG :(
16-08-2015 6:38 PM
The reason I ask for a traceroute or ping test from the command prompt is to rule out browser issues.
Re: BNG :(
16-08-2015 6:50 PM
Re: BNG :(
16-08-2015 7:21 PM
Works for me (although I'm on FTTP but still have speed issues when connected to gateway's with BNG in their names)
You are only disconnecting the session to Plusnet in the router , never the modem so you line sync to the cabinet is unaffected.
Re: BNG :(
16-08-2015 7:22 PM
Re: BNG :(
16-08-2015 8:03 PM
But presumably the rest of the world knows how to configure them properly.
Quote from: AndyH The same bits of kit also handle most of the world's internet traffic - you would struggle to not find a MX960 on a traceroute.
Re: BNG :(
16-08-2015 8:04 PM
Re: BNG :(
16-08-2015 8:06 PM
Not happy
http://www.thinkbroadband.com/speedtest/button/143975507476754834866-mini.png
Re: BNG :(
16-08-2015 8:12 PM
Cheers for that.
Quote from: georgelnx You just hop and hope that the first time that you get a good gateway (as in good for you).
Re: BNG :(
16-08-2015 8:13 PM
Re: BNG :(
16-08-2015 8:24 PM
