BBC Iplayer
rongtw
Fixes: 12
BBC Iplayer
once again BBC iplayer is terrible My connection seams fine 73/18   Current SNR Margin: 6.0 dB
had some wierd errors see snips.
Can PN do a check please Thumbs Up
rongtw
Fixes: 12
Re: BBC Iplayer
so no one any input ?Huh
rongtw
Fixes: 12
Re: BBC Iplayer
still buffering , checked my router log i keep getting this ?Huh
dnsmasq-dhcp[435]: not giving name localhost to the DHCP lease of 192.168.1.112 because the name exists in /etc/hosts with address 127.0.0.1
Fixes: 54
Re: BBC Iplayer
That message says whichever computer has the IP 192.168.1.112 on your LAN  claims its hostname is localhost. Alternatively an attempt is being made to identify it as localhost in the router's connected device settings.
Using localhost on the LAN is not allowed because localhost is set in the router's /etc/hosts file as the loopback host 127.0.0.1.
David
rongtw
Fixes: 12
Re: BBC Iplayer
Cheers spraxyt ,, i think i got it Thumbs Up
