Awful speeds, pings and frequently no service
- Re: Awful speeds, pings and frequently no service
23-09-2015 8:22 PM
Have been a very happy plusnet customer for a couple of years on the 80/20 unlimited. Since ysterday my connection drops, then reconnects after a short time (changes). Then this afternoon it dropped for an hour and since then performance has been awful.
Estimated line speed:
Current line speed:
14.5 Mb
BTW Performance Test.
1. Best Effort Test: -provides background information.
Download Speed
1.59 Mbps
0 Mbps 3.02 Mbps
Max Achievable Speed
Download speedachieved during the test was - 1.59 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-3.02 Mbps .
Additional Information:
IP Profile for your line is - 3.02 Mbps
Upload Speed
0.59 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 0.59Mbps
I've reported it via faults. The connection is a bit more stable now. Just very slow.
Current line speed:
14.5 Mb
Download Speed
1.59 Mbps
0 Mbps 3.02 Mbps
Upload Speed
0.59 Mbps
0 Mbps 20 Mbps
Message 1 of 4
(729 Views)
3 REPLIES 3
24-09-2015 1:59 AM
First guess would be that you've had some impulse noise, crosstalk or other upstream line fault which has given you loads of disconnects. DLM's then kicked in as you've exceeded its threshold, hence the lower speeds. You may have to get PN to reset everything for your original speed to come back.
A few days after my fibre went active (80/20), their systems magically put me onto an ADSL2+ speed profile -- imagine my surprise!
Message 2 of 4
(487 Views)
24-09-2015 8:52 AM
Thanks. I'll wait for the staff to wake up
A drop overnight between 3:02 - 3:54 improved the situation slightly. But not by much.
At least I can get some work done now.
Download Speed
2.81 Mbps
0 Mbps 3.32 Mbps
Download speedachieved during the test was - 2.81 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-3.32 Mbps .
IP Profile for your line is - 3.32 Mbps
Upload Speed
3.41 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 3.41Mbps
Download Speed
2.81 Mbps
0 Mbps 3.32 Mbps
Upload Speed
3.41 Mbps
0 Mbps 20 Mbps
Message 3 of 4
(487 Views)
24-09-2015 3:08 PM
BT have come out and found a short in the cable 350m away. Just waiting on the wife to reset the BT modem. But the wholesale checker shows IP Profile for your line is - 67.69 Mbps
I think I might be the lucky one to have good service from BT round here
Message 4 of 4
(487 Views)
