Authentication and IP Config Failure
- Authentication and IP Config Failure
25-04-2019 11:46 AM - edited 25-04-2019 11:46 AM
Hi, please help - I am getting continued wifi connection issues with my Plusnet router from multiple devices and none of them will maintain a wifi connection.
Mainly testing from my Pixel 3xl but seen the same problems on a pixel 2xl and a Nokia 7.1, Pixel slate and a Chrome Cast.
The phones will not maintain a constant WiFi connection so every time I open them, they try to reconnect - they will initially connect, then connection drops and most of the time will not reconnect directly to the router - they will however connect to my wifi booster
I get was getting an error "Authentication Error" - Searched for this yesterday and followed your instructions HERE
to split the 2.4 and 5Ghz frequencies out - this seemed to work last night but an getting issues again today - in fact this morning I've been getting "IP Configuration Failure" on the phones when it tries to re connect.
I've done a manual rescan to find best channels - made no difference
Looking at the logs, I get client associated and dissociated messages every 10 secs:
11:04:41, 25 Apr. ath00: STA 3c:28:6d:13:c8:01 IEEE 802.11: Client associated
11:04:38, 25 Apr. ath00: STA 3c:28:6d:13:c8:01 IEEE 802.11: Client disassociated
11:03:52, 25 Apr. ath00: STA 02:0f:b5:a8:61:d5 IEEE 802.11: Client associated
11:03:52, 25 Apr. ath00: STA 02:0f:b5:a8:61:d5 IEEE 802.11: Client disassociated
11:03:51, 25 Apr. ath00: STA 3c:77:e6:92:a5:3e IEEE 802.11: Client associated
Please can you advise how to resolve this, it's very frustrating. Thanks
I'm on a FTTP connection if that makes any difference
Re: Authentication and IP Config Failure
25-04-2019 2:10 PM
Hi @spendare,
Please accept my apologies for the issue with your broadband service.
Thank you for confirming that you have split the 2.4GHz / 5GHz frequency bands. After testing the line, it appears stable leading up to the router. As you have split the frequency bands, could you try changing the wireless channel by following the guide below for both bands then try connecting to each of them individually.
1) To connect to your Hub One, you will need to open a browser and go to http://192.168.1.254
2) You should come to a page with information about your connection, click 'Advanced Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) In your 'Advanced Settings' page, you will need to change the settings within the 2.4 GHz Wireless tab and the 5 GHz Wireless tab.
5) Under the correct heading, you will need to find 'Channel Selection' on the list and change this from 'Automatic' to any one of the other channels, This can also need doing under '5 GHz Wireless' to cover both signals.
Alternatively you can try the smart wireless channel selection, you can do this by following the guide below.
1) Go to 'Settings'.
2) Click 'Refresh your wireless channel to avoid interference'.
3) Hit 'refresh' at the bottom of the page.
4) Once complete, allow a few minutes for the new channel to take effect
If you haven't done so already, due the the message 'IP Configuration Failure' please factory reset the router by holding a pin or paper clip in the reset slot at the back until the light goes green then allow some time for the service to reconnect.
Let us know how you get on.
Thank you.
25-04-2019 3:36 PM
Thanks for the reply, I have already clicked on the refresh for the smart wireless as you described.
Appreciate it's not the connection leading to the router as I have 2 PC's on an Ethernet connection and these remain stable.
I will try a factory reset - can you advise though please, should my phones maintain a constant wifi connection?
Is it abnormal for them to reconnect every time I try to use them?
25-04-2019 4:00 PM
@spendare wrote:
...should my phones maintain a constant wifi connection?
Yes
Yes
It is worth downloading a free wifi sniffer app, I use Wifi Analyser on an Android phone. With this you can see all the channels in use and select the best. Check both at the router location and where you use your devices.
Also now that you've split the bands have you tried each in turn? If you've followed the standard advice you will only be looking at the 2.4GHz band. You need to go back into your device wifi settings and connect to the 5GHz band.
When you've had enough of Plusnet's router go onto Ebay and buy a BT Smarthub 6 for around £20. Just make sure that you get the FTTC version. This has four yellow LAN sockets. Avoid the FTTP version, which has a red WAN sticker fixed to one of the LAN ports. Setting instructions are here https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85...
25-04-2019 4:12 PM
Thank you @Baldrick1 - this has been doing my head in for several months now, even bought a new phone as I thought it was a problem with the Nokia I had before (still was a good excuse to get the 3xl!)
I am close to ditching the PlusNet router.... Might actually consider swapping ISP's completely although I'm on FTTP so limited choices. Which also leads me to ask, you say get the FTTC BT router and avoid the FTTP one - surely I would need the FTTP one though as I'm on FTTP...
Thanks again
Dan
25-04-2019 7:56 PM
Yes you would need the FTTP version. I understand that this needs you to also have a modem.
25-04-2019 9:52 PM
If all the usual fixes do not fix the issues with authentication, could you please post up the routers software version - it's located at the bottom of any router page.
(I could be wrong, but kinda guessing it ends in 263 - if it does the replacement phone was probably a waste of money too).
26-04-2019 9:36 AM
26-04-2019 10:21 AM
26-04-2019 10:31 AM
26-04-2019 10:46 AM
26-04-2019 12:08 PM
Thanks for adding your details to the linked thread, @spendare - Just a quick update to let you know we've seen it and will respond when we have further updates on the rollback/firmware queries.
Best wishes
Dave
26-04-2019 12:11 PM
26-04-2019 12:16 PM
26-04-2019 12:20 PM
