Authentication Failure?
TheHorseman
As I was leaving for work this morning I noticed that the light on my router was flashing orange (Airport Extreme) meaning no auth with Plusnet, DSL is in sync. I have also discovered that a work colleague also Plusnet and also on Haslington (Crewe) exchange is also off. Maintenance or something else?
Fixes: 170
Re: Authentication Failure?
I've discussed this with a colleague and they've advised that rebooting your router when you get home should get you back online Smiley
 Harry Beesley
TheHorseman
HarryB, Thank you I'll try that when I get home. I did try a quick reboot of the router before I left for work with no change.
I have noticed with the AE that sometimes it will re-connect after an outage and sometimes it won't (mostly it doesn't  Roll eyes )
TheHorseman
@HarryB, rebooted the router when I got home and all is back to normal.
nbk
What gateway are you on now?
http://usertools.plus.net/@gateway/
dick:quote
Fixes: 170
Glad to hear you're back online after a reboot. Thanks for letting us know  Smiley
 Harry Beesley
TheHorseman
@nbk, now on gateway psb-ar01. I guess this must be the new network.
Fixes: 46
Yes, that's on the new network.
David
