Attempting to use PPPoE on PS4
- Attempting to use PPPoE on PS4
31-07-2016 1:32 PM
Hello, quick question regarding PPPoE. I'm attempting to get a NAT type 1 on my PS4 console by connecting via PPPoE. I have my username and password, and try to connect, but the PS4 always fails to resolve an IP address. I'm sure the username and password are correct because I use them if I need to change something on my router via Telnet. Has anyone else had issues with trying to connect via PPPoE? Thanks.
Re: Attempting to use PPPoE on PS4
31-07-2016 7:55 PM
If you wish to use PPPoE, is your PS4 connected directly to a VDSL modem such as the ones provided by Openreach ?
31-07-2016 9:41 PM
Yep, it's hooked up to one of these from Amazon;
https://www.amazon.co.uk/gp/product/B013OXVA6M/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
The PS4 works perfectly fine otherwise, but I have a NAT type 2. I'd rather just connect via PPPoE if that's possible really.
