Attainable v's Actual
- Attainable v's Actual
07-04-2016 11:23 AM
Is it normal to have a large difference in attainable and actual rate in the download speed on VDSL connections?
The Plusnet current line speed gives me 56.2 mb, I guess that's the same as the actual DS rate below?
---------------------- ATU-R Info (hw: annex A, f/w: annex A/B/C) -----------
Running Mode : 17A State : SHOWTIME
DS Actual Rate : 59196000 bps US Actual Rate : 19999000 bps
DS Attainable Rate : 74127488 bps US Attainable Rate : 23333000 bps
DS Path Mode : Interleave US Path Mode : Fast
DS Interleave Depth : 1559 US Interleave Depth : 1
NE Current Attenuation : 16 dB Cur SNR Margin : 5 dB
DS actual PSD : 7. 2 dB US actual PSD : 12. 5 dB
NE CRC Count : 5 FE CRC Count : 37080
NE ES Count : 1 FE ES Count : 31425
Xdsl Reset Times : 0 Xdsl Link Times : 1
ITU Version[0] : b5004946 ITU Version[1] : 544e0000
VDSL Firmware Version : 05-07-04-03-00-07 [with Vectoring support]
Power Management Mode : DSL_G997_PMS_L0
Test Mode : DISABLE
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 19 dB Far SNR Margin : 14 dB
CO ITU Version[0] : b5004244 CO ITU Version[1] : 434da459
DSLAM CHIPSET VENDOR : < BDCM >
Near End Far End Note
Trellis : 1 1
Bitswap : 1 1
ReTxEnable : 0 0
VirtualNoise : 0 0
20BitSupport : 0 0
LatencyPath : 0 0
LOS : 0 0
LOF : 0 0
LPR : 0 0
LOM : 0 0
SosSuccess : 0 0
NCD : 0 0
LCD : 0 0
FECS : 909903 1455806 (seconds)
ES : 1 31425 (seconds)
SES : 0 11 (seconds)
LOSS : 0 0 (seconds)
UAS : 28 76623 (seconds)
HECError : 0 0
CRC : 5 37080
RsCorrection : 0 0
INP : 0 25 (symbols)
InterleaveDelay : 0 1000 (1/100 ms)
NFEC : 254 63
RFEC : 16 16
LSYMB : 5374 19931
INTLVBLOCK : 127 63
AELEM : 0 ----
Re: Attainable v's Actual
07-04-2016 11:39 AM
I have seen it happen before but it's not a common occurrence.
Your current DLM profile is "0.128M-60M Downstream, Interleaving High - 0.128M-20M Upstream, Error Protection Off" which is why your sync speed isn't any higher then what it is and in addition you have a high level of interleaving on your line.
At the moment you're just below your estimate but there might not be much we can do.
07-04-2016 11:46 AM
Thank you for checking that info for me. Is the interleaving likely to be caused by something that I can change?
07-04-2016 12:19 PM
Interleaving can be added for any number of reasons but it can take time to remove I'm afraid.
You can raise this to our Faults team if you'd like but they may not be able to do anything.
If you want to do this the link is https://faults.plus.net
