Asus rt-ac68u on plusnet fibre
- Asus rt-ac68u on plusnet fibre
01-02-2016 2:59 PM
Hi folks, i hope someone may be able to help me.
At the moment i use the Plusnet modem/router to connect to ADSL, and use the Asus rt-ac68u for routing round the house.
Fibre is going to be available in my area within the next 2 months, and i see that Plusnet are using an all-in-one router now for fibre.
Will this work with the Asus router or should i buy a new modem for connecting to fibre ? I have seen some posts recommending the Draytek Vigor 130 to use.
Cheers
Chalky
Cheers
Chalky
Message 1 of 3
(1,031 Views)
2 REPLIES 2
Re: Asus rt-ac68u on plusnet fibre
01-02-2016 8:03 PM
The draytek would work fine; or you could buy a hg612 (openreach FTTC modem) off ebay/freecycle etc.
Ian
Ian
Message 2 of 3
(718 Views)
02-02-2016 12:18 AM
To be fair, if you have managed to get your current configuration to work, you should be able to use your current router to work with a Plus Net Hub One to work.
Message 3 of 3
(718 Views)
