Asus RT N66U settings
artfulbodger
Can anyone advise on how to set up an Asus RT N66u router please, especially port forwarding. I've gone through all the recommended steps and have got a steady rock-solid connection, however I can't seem to see any of the ports that I thought I'd opened when I try to view them remotely. But when I'm on the network at home I can see all the ports without a problem. Strangely none of the Internet radios in the house connect to the router now either.
The router had been set up for use on an old BT Infinity connection. I simply went in and changed the username and passwords as recommended on the PlusNet connections page. I thought the other settings the router would take care by itself, as when I originally set it up under BT.
This getting confusing ... !
