Asus RT-AC66U setup?
- Asus RT-AC66U setup?
02-05-2015 8:49 AM
Morning all,
I bought this router to replace the one that came with the fibre package. Note, this is not replacing the BT fibre modem.
It's correctly detecting PPPoE, when asked for username/password I'm putting in the username/password that I use to login to my account on the main plusnet site as I'm sure I found in a guide on here somewhere.
It's saying it's incorrect.
Is there something I'm missing?
Back to the stock router for now 😕
Cheers!
Paul.
Cheers!
Paul.
Message 1 of 3
(864 Views)
2 REPLIES 2
Re: Asus RT-AC66U setup?
02-05-2015 10:34 AM
That sounds right, but you need the full email address I think, not just the user name. (unclejack@whatever.net, not simply unclejack)
02-05-2015 11:13 AM
Brilliant, all sorted and many thanks
Message 3 of 3
(599 Views)
