Asus DSL-N66U - Random Wireless delays
- Asus DSL-N66U - Random Wireless delays
15-04-2015 7:42 PM
Not sure what's going on, nothing jumping out at me in the logs, so wondering if its a DSL connection issue. It's got the newest Firmware installed, which got it working pretty well.
the current settings are below:
DSL Driver Version FwVer:5.4.11.29_A_TC3095 HwVer:T14.F7_0.0
DSL Link Status up
DSL Uptime 11 days 17 hours 33 minutes 25 seconds
DSL Modulation ITU G.993.2(VDSL2)
ANNEX Mode ANNEX_A
SNR Down 7.0 dB
SNR Up 10.9 dB
Line Attenuation Down 2.2 dB
Line Attenuation Up 1.4 dB
Path Mode Interleaved
Data Rate Down 67615 kbps
Data Rate Up 19999 kbps
MAX Rate Down 93136 kbps
MAX Rate Up 31988 kbps
POWER Down -5.7 dbm
POWER Up -5.5 dbm
CRC Down 27
CRC Up 47
Anyone got any ideas? Thank you
DSL Link Status up
ANNEX Mode ANNEX_A
SNR Down 7.0 dB
SNR Up 10.9 dB
POWER Down -5.7 dbm
POWER Up -5.5 dbm
CRC Down 27
CRC Up 47
Message 1 of 7
(1,088 Views)
6 REPLIES 6
Re: Asus DSL-N66U - Random Wireless delays
15-04-2015 7:58 PM
Quote from: fuzed
ANNEX Mode ANNEX_A
In would double check the above.
All the VDSL2 modem / routers I've use have all reported Annex B.
Message 2 of 7
(571 Views)
18-04-2015 1:29 PM
thanks, shall have a look at it...
Message 3 of 7
(571 Views)
18-04-2015 1:33 PM
Annex b appears to be for Germany, poland etc. not the uk.
Message 4 of 7
(571 Views)
18-04-2015 2:57 PM
That's for ADSL not VDSL.
Message 5 of 7
(571 Views)
20-04-2015 5:01 PM
Ok, shall take another look at it cheers.
Message 6 of 7
(571 Views)
22-04-2015 11:45 AM
Worked out the issue, the 2 different Wireless networks had the same name, renamed on and connected to that only and it's great.
Message 7 of 7
(571 Views)
