Asus DSL-AC68U
- Asus DSL-AC68U
Asus DSL-AC68U
04-01-2016 8:56 PM
I have just got the Asus DSL-AC68U and I cannot seem to connect at all.
I have setup the WAN connection as VLAN.
DSL Modulation: ADSL2+
Annex mode: Annex A
It just will not connect. Any ideas?
Re: Asus DSL-AC68U
04-01-2016 9:02 PM
Edit: Should have paid attention to what board you posted in. Try the attached settings. I've blurred my PPP username in the second screengrab, you'll need to enter yours there.
Re: Asus DSL-AC68U
04-01-2016 9:26 PM
Re: Asus DSL-AC68U
04-01-2016 9:40 PM
Assuming you're plugged straight into the phone line, you need to be using direct VDSL, not DSL or VDSL over WAN. The VLAN ID needs setting to 101 and the profile should be 17a.
Have you tried mimicking my settings exactly, and did you make sure to save them after visiting each page?
Re: Asus DSL-AC68U
04-01-2016 11:04 PM
Nothing works. I have even tried by-passing the modem. Nothing.
I can't find anywhere else to go direct VLAN
Re: Asus DSL-AC68U
04-01-2016 11:46 PM
Does it sync? i.e. does the 'globe' status icon at the top right stay solid green? Are there any clues in the logs?
Others round these parts have exactly the same model router as yours so might be worth checking out some older threads.
Re: Asus DSL-AC68U
04-01-2016 11:49 PM
Quote from: ceewild I have even tried by-passing the modem. Nothing.
Not 100% sure what you mean here, but if you're talking about the Openreach modem, you don't need it. The DSL cable should go from your phone socket direct into the appropriate port in the back of the ASUS.
Re: Asus DSL-AC68U
04-01-2016 11:50 PM
In the log it drops on modem connection. It dials and then just says hangs up.
Re: Asus DSL-AC68U
04-01-2016 11:50 PM
Quote from: Bob
Done that to start. It can be run in dual mode and it by-passes modem.
Re: Asus DSL-AC68U
05-01-2016 4:08 PM
Quote from: ceewild In the log it drops on modem connection. It dials and then just says hangs up.
The concept of dialling/hanging up seems a bit odd. Are you able to copy/paste some of the router log entries? If the log entries are in the same place as mine then they'll be under System Log - General Log.
I can see we gave you instructions on how to establish a PPP connection from the PC to the modem recently and I want to be sure that's not being confused with the problems you're having with the Asus.
If it's of any help, your recent successful connections to us, look like this:
Session Started | Session Ended | Session Duration
23:00 04/Jan/2016 N/A 16:29:47 (on going)
21:24 04/Jan/2016 22:37 04/Jan/2016 1:12:3
21:14 04/Jan/2016 21:20 04/Jan/2016 0:6:21
20:46 04/Jan/2016 21:10 04/Jan/2016 0:24:1
19:50 04/Jan/2016 20:10 04/Jan/2016 0:19:13
22:24 02/Jan/2016 18:49 04/Jan/2016 One Day, 20:24:55
Re: Asus DSL-AC68U
05-01-2016 4:52 PM
Re: Asus DSL-AC68U
05-01-2016 7:05 PM
DNS Servers not being auto is optional
Re: Asus DSL-AC68U
05-01-2016 7:46 PM
Constant error:
Aug 1 00:10:51 pppd[965]: Timeout waiting for PADO packets
Aug 1 00:10:52 hour monitor: daemon is starting
Aug 1 00:10:52 hour monitor: ntp is not syn
Aug 1 00:11:22 hour monitor: daemon is starting
Aug 1 00:11:22 hour monitor: ntp is not syn
Re: Asus DSL-AC68U
05-01-2016 10:29 PM
Re: Asus DSL-AC68U
06-01-2016 11:22 AM
@ceewild - try rebooting router.. if not check you're wired up correctly
