Asus DSL-AC68U slow speed
- Asus DSL-AC68U slow speed
27-10-2018 4:38 PM
I recently changed from the plusnet one hub to an ASUS DSL-AC68U prmarily to use it's internal VPN feature, initially I couldn't get it to connect at all, but after updating to the latest firmware it connects ok, but at a much lower speed the one hub did.
The one hub gave around 36m down and 5m up, there ASUS is only managing 16m down and 1.5 up, I have left t conected for a wek but nothign has improved, the line stats are below,
Data Rate |
22550 kbps
1725 kbps
Max Rate |
50424 kbps
4889 kbps
and show that he line is capable of higher speeds than it is currently delivering, I've posted my current settings below but have tried changing a few parameters to no avail, anyone here have any ideas?
Re: Asus DSL-AC68U slow speed
28-10-2018 10:27 AM
Hi @pnandy,
After testing the line, I have detected a potential fault. Your sync rate is 18.9Mbps and high amount of errors are occurring. This is usually an external fault however, it seems too much of a coincidence that this has been detected after changing to a new router.
Could you please reconnect the Hub One and let us know when you have reconnected it so we can rerun the test on the line.
Thank you.
28-10-2018 11:13 AM
DLA and SRA should both be enabled. UPBO should be AUTO. The Mediatek modem in the DSL-AC68U is not very good and may give you a lower sync rate than the Plusnet modem. The DSLAM no longer support G.INP for Mediatek modems. Ideally you would use a supported modem and use the DSL-AC68U just as a router.
28-10-2018 12:16 PM
Jubby,
Thanks for looking at this for me, on the ASUS I just got 18.6 down and 5.6 up.
I have now connected the plusnet hub one and am now getting 30.5 down and 4.3 up
I'll leave the hub one connected now so you can test the line..
28-10-2018 12:35 PM
Just as an aside I found I achieved much better speeds with that router if I enabled 'Non-standard G.Vector.
It took around 24 hours for change to be effective.
29-10-2018 9:36 AM
Thanks for reconnecting the Hub One.
Our tests are still showing the external fault so this may be a genuine fault rather than a router issue.
I've raised this to our suppliers so they can investigate further and we'll update you when we know more. You can track the progress by going here.
Let us know if you have any further questions
29-10-2018 1:35 PM
Thanks for this, we did loose the BT line entirely a few months back, perhaps this is related?
a B.T. engineer looked at the slow speed issue and thought it might be the router, but this dodnt make much differnce.
29-10-2018 4:29 PM
No problem @pnandy,
It could potentially be related however, I have no way of being certain. At least this time round two routers have been tested therefore, we know it is not the equipment.
