Asus DSL-AC68U Settings
- Asus DSL-AC68U Settings
05-03-2015 9:00 AM
I have recently bought an Asus DSL-AC68U but for the life of me cannot get it to work. I have tried multiple settings from diffferent sites but still nothing. The DSL light flashes around 10 times does nothing and keeps repeating itself every 30 seconds. The main instructions i followed were from here http://community.plus.net/forum/index.php/topic,134516.0.html/. I can try and provide as many details as needed.
Please help
Regards
Re: Asus DSL-AC68U Settings
05-03-2015 12:26 PM
05-03-2015 1:00 PM
05-03-2015 3:29 PM
05-03-2015 5:20 PM
A new one, Version 3.0.0.4.376_2187, came out on 2015/02/26 :
showing item 14 as Fixed sync issue with certain DSLAM
I have the previous version 3.0.0.4.376_2160.
05-03-2015 7:15 PM
See attached the settings i have.
05-03-2015 7:18 PM
05-03-2015 7:48 PM
See if you then get a solid dsl light.
06-03-2015 11:16 AM
I don't require the filter that it came with do I? All I've done is take the line cable from the openreach modem and plugged it into my router and also configured it with my PPPoE settings.
06-03-2015 12:18 PM
06-03-2015 12:40 PM
06-03-2015 12:56 PM
Other than that, the settings look to be OK.
As others have said, the DSL connection should be made even before you do anything with the PPPOE settings. If that's not happening and you've reset the device and tried then it could be a faulty device.
06-03-2015 1:00 PM
If, when you have reset the Asus so there are no settings entered, you connect the dsl cable you should get a solid dsl light.
You do not need the splitter if you do not need one for the BT modem.
I literally took the router out of the box and, like you, disconnected the cable from the BT modem and plugged it into the dsl port on the Asus and within a few seconds there was a solid dsl light. I then connected a pc to input the plusnet username and password settings to the Asus.
07-03-2015 8:09 PM
Any idea if i know whether i have a faulty line even though it works fine on my bt modem and plusnet router? I have a decent speed of 36.63Mbps (down) and 11.44Mbps (up) so to me it looks ok.
My phone line though goes beep, beep. beep, beep with one second intervals instead of having a continuous dial tone if that helps. (I can still make calls though).
