Asus DSL-AC68U Settings
- Re: Asus DSL-AC68U Settings
01-12-2014 9:34 AM
Does anyone else have this router (or another similar Asus model) that could let me know the manual settings I need to apply to get the unit working correctly with PlusNet fibre.
Many thanks for your help.
01-12-2014 9:44 AM
http://community.plus.net/forum/index.php/topic,134308.0.html just make sure you get the username/password correct.
01-12-2014 9:56 AM
01-12-2014 12:53 PM
01-12-2014 6:16 PM
I've used the [username]@plusdsl.net as the login name.
If you could shed any further light on this, I'd be really grateful.
01-12-2014 6:24 PM
02-12-2014 8:51 AM
Many thanks.
02-12-2014 11:36 AM
http://192.168.1.1/Advanced_WAN_Content.asp on this page wan type > dsl vdsl wan ptm
add or edit a pvc
PVC Setting
WAN Connection Type PPOE
Enable WAN Yes
Enable NAT Yes
Enable UPnP Yes
802.1q
Enable Yes
VLAN ID 101
WAN IP Setting
Get the WAN IP automatically Yes
WAN DNS Setting
Connect to DNS Server automatically Yes
enter your full username and password
once all the above is changed click ok at bottom
http://192.168.1.1/Advanced_ADSL_Content.asp here change vdsl profile to 17a the rest u can leave as it is.
i think thats all it is. i dont have the latest firmware so if you have any questions just ask
03-12-2014 9:36 AM
04-12-2014 9:20 AM
Thanks for all your help.
04-12-2014 12:57 PM
04-12-2014 3:13 PM
30-01-2015 11:59 PM
04-03-2015 7:41 PM
18-08-2015 8:25 PM
Quote from: dansonadz1 Sorry to take over this thread but i have also bought this router and for the life of me cannot get it to work. I have followed the settings as described in this thread but to no avail cannot get it to work. Can anyone help please.
I have this router too, running firmware version 3.0.0.4.378_6986.
It cannot connect to the line. The syslog shows "Timeout waiting for PADO packets"
Does anyone have screenshots of their settings which work with this firmware version ?
Edit:
Have established a connection based on the settings in reply #2 on this thread:
http://community.plus.net/forum/index.php/topic,142495.0.html
