Are these the correct speeds
FIXED- Subscribe to RSS Feed
- Are these the correct speeds
30-09-2021 12:07 PM - edited 30-09-2021 12:12 PM
Hi upgrade to Fibre Extra and seems slow. It says on USWITCH SPEED TEST DOWNLOAD 4.8 MPS and on BT test 4.93 MPS. My account shows i am still on Broadband unlimited which i am not
Fixed! Go to the fix.
Re: Are these the correct speeds
30-09-2021 12:23 PM
@EDD1 Those speeds do seem slow. Can you do the 'Additional Diagnostics' on the BT test, please?
When did you switch to Fibre Extra, and have you had confirmation that the order has completed?
30-09-2021 12:46 PM - edited 30-09-2021 12:48 PM
hope this is what your looking for. was upgraded on Wednesday
30-09-2021 12:51 PM
That is what I was looking for, thanks - it proves your upgrade is not completed. You need Help Team intervention.
30-09-2021 12:52 PM
It looks like you are still on ADSL, or that is all your line will support.
If you enter your phone number into the BTW DSL checker I should give us a bit more of an idea.
If you could post the results, but hide your phone number.
30-09-2021 12:57 PM
Here you go
30-09-2021 12:59 PM - edited 30-09-2021 1:00 PM
Well, you can get Fibre to the cabinet at a reasonable speed, but you are still on ADSL.
What communication have you had from Plusnet over this matter?
30-09-2021 1:01 PM - edited 30-09-2021 1:09 PM
more information
30-09-2021 5:26 PM
Hiya @EDD1, thanks for getting in touch. I am sorry to hear your speeds haven't yet increased as expected.
I have provided a further response regarding this here for you: https://www.plus.net/wizard/?p=view_question&id=218405228
30-09-2021 5:31 PM
@LaurenB Not that this is any of my concern, but if a customer posts on here and gets a Community response, would it not be an idea to give those Community members an idea of the issue - unless of course it is a 'commercial secret'?
30-09-2021 5:43 PM
Agreed, @jab1
Too often we see a response such as
which should only be necessary for account/billing matters.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
01-10-2021 9:21 AM
01-10-2021 9:27 AM
Thanks @adam945 - so not commercially sensitive, and a straight answer on the forums would have saved us wondering.
01-10-2021 11:19 AM
Thanks @adam945
Seeing tech matters through to a resolution helps us to help in the future. 🙂
