Are there any routers that actually work reliably with this service?
andyp24
Re: Are there any routers that actually work reliably with this service?
Hi all
Thanks for the input to the discussion. I checked on the SmartHub 6 and there doesn't seem to be any way to change the SNR settings in this modem/router.
I know the cabling is aluminium because several OpenReach engineers who've been to the house for various investigations have commented on it (the most common adjective they used was "crappy"). We were an Exchange-Only line until very recently, which meant we got Fibre Access after the rest of the village cabinets were converted. Then a new green cabinet was built right at the exchange and all the EO lines were moved to it so we could also get FTTC service. Not sure how old the lines are, but I've been told by OpenReach that there's no plan / intention to upgrade them as our service is "acceptable".
What I don't understand in all this discussion of the line quality is why the PlusNet Hub One would stay connected to the broadband for months at a time, and the SmartHub did for the first 6 months or so, but now drops off regularly. That would seem to imply either the Hub's gone faulty somehow (or a firmware upgrade has messed something up?) or the line has changed - which was why I was so surprised when I reconnected the original Hub One and it connected immediately and solidly when the Hub 6 was refusing to at all.
Any ideas?
dws1900
@andyp24
All modems are not equal, some modems are better than others with dealing with noise, crosstalk, interference (don't forget, it is radio based, not complete fibre) and all the other gremlins that live in the connection box's,  Smiley
It would appear from your comments that the service is degrading, so best bet is to get a GEA test done by asking the nice PN support people Smiley  Its free and painless
I could say go out a buy the latest most powerful fantastic router, which would cost loads of money, and you could still have problems. (It happened to me on adsl, interference, five properties away, lost 2Mbs till OR sorted it)
andyp24
Do I need to ring them up and ask for that, or post a message in a particular forum?
dws1900
@andyp24
You could ask here, or log in with your plusnet account and raise a ticket.
You will need to connect whatever modem you choose, via a filter to the master socket, to rule out any issues with the internal wiring.
See here
connection-troubleshooting
andyp24
I have a new double master socket, so have been told I don't need to use the old-style microfilters....?
VileReynard
Fixes: 20
What's the point in planting a cabinet at the exchange?
Your internet comes entirely over wires - just the same as when you had ADSL.
There is no fibre connection involved. Absolutely none.
VileReynard
Fixes: 20
True.
dws1900
@andyp24
Again these can vary. If it was me I would use the PN supplied filter and modem, get the test done, then you are using all PN's equipment, and bypassing the master socket based filter completely.
Somewhere in the plusnet web site there is documents on how to do this.
https://www.plus.net/help/broadband/connection-troubleshooting/
dws1900
@VileReynard
Re cabinet siting. Mine is close to the exchange(200m) , while some other properties on my road are connected to a closer dslam, 0.5km away.
Why, ease of connection, cheaper option, better revenue, get people on line quicker and worry about the issues later.
Also this seems to be the issue with EO lines, where OR wont put a dslam closer to the property with the required PCP box.
Annoyingly within 0.5km, there is a new estate with fttp.
VileReynard
Fixes: 20
I am 2km from the exchange & got 6Mbps on a good day on ADSL over the copper wires.
I am now 250m from a "green box" and get 70Mbps on "fibre".
andyp24
@VileReynard I take your point, and did question it myself as to what the difference would be by inserting a new Green Cabinet very near the exchange. However, this is what I was told - all the EO lines in the village were moved into a new cabinet built specifically for us, and near the exchange, and this allowed us to be given a FTTC service. Yes, I totally understand that the length of copper / aluminium in the circuit hasn't changed (apart from a few metres maybe). But previously we got 7Mbs download, and now we get 30Mbs, so something did! Must be something to do with compatibility between the higher speed service and the equipment we were previously connected to in the exchange, I guess.
@dws1900 I'll request the GEA test, although will have to wait until tomorrow to disconnect the BT router and restore the Plusnet One. I'll try and get stats from that one's setup page when I do.
Cheers
Andy
cee2
re , Are there any routers that actually work reliably with this service?
fttc ,netgear d6400 / ac1600 ,been great these past few years ,got mine  from amazon , my  bt dumb hub
would disconnect ,  have a computer "chat "  with a server ,then reconnect me, every time it did it the line speed would drop ,system thinks line fault, with no disconnects speed would slowly come back up  ..
VileReynard
Fixes: 20
Don't shoot the router!
cee2
use a hammer instead !!!
andyp24
Here's the result of the GEA test. If anyone can interpret it, please let me know what you think!
Andy
KBDxDSL Status Check Circuit ID:CBUK97370876Service ID:BBE [Removed]Telephone NO.:NATest Executed On:15-02-2019 15:13:07xDSL Status Test SummarySync Status:Circuit In SyncGeneral InformationNTE Status: NTE Power Status:PowerOnBypass Status:   Upstream DSL Link InformationDownstream DSL Link InformationLoop Loss:6.912.5SNR Margin:7.33.1Errored Seconds:02HEC Errors:0 Cell Count:00Speed:127122850 Maximum Stable Rate (KBPS):20416Fault Threshold Rate (KBPS):16333Mean Time Between Retrains (Seconds):86400Mean Time Between Errors Upstream (Seconds):734Indicative Line Quality:AMean Time Between Errors Downstream (Seconds):197Custom ThresholdsMTBR_RED:MTBE_RED:MTBR_GREEN:MTBE_GREEN:
Moderator's note by Adie (Dvorak) removed bbeu
