Approved third party routers
- Approved third party routers
06-04-2020 10:00 AM
Is there any advice on third party routers that are able to connect to the Plusnet network.
Re: Approved third party routers
06-04-2020 10:13 AM
are you on fibre or adsl?
what features are you looking for?
06-04-2020 10:24 AM
You can use any third parti ADSL/VDSL modem/router or with a bit of setting up a BT Home Hub 5 or Smarthub 6, you will find the instructions for setting BT hubs on the router board. Settings for third party routers here. https://www.plus.net/help/broadband/broadband-connection-settings/
06-04-2020 10:35 AM
I am seeing a 20Mbs drop out on wi-fi versus an ethernet connection. I'm wondering if a more powerful wi-fi router will help or considering a mesh system.
06-04-2020 10:37 AM
Thanks that's very helpful. Primarily I'm seeing a big drop off over wi-fi v ethernet. I know there will be a difference but wonder if a more powerful router v the Plusnet one will help deliver a better signal?
