Apple downloads slow
- Apple downloads slow
02-04-2015 11:16 AM
Hi, I think downloads from Apple servers/Apple CDN are going 4-5 times slower than they should on Plusnet, or at least on my Plusnet connection.
These are used for things like iOS updates and firmwares: e.g http://www.redmondpie.com/download-ios-8.1.3-links-for-iphone-and-ipad/
I get around 12-20Mb/s on Plusnet. I know that on BT retail and Sky connections I access, line speed at around 74Mb/s is consistently achieved (and we are well outside of a freshly released iOS version).
It appears Plusnet is downloading from defra1-vip-sx-005.aaplimg.com (name suggests intended for Germany & France?), and routing via Germany. I know on BT retail, it always downloads from uklon5-vip-sx-005.aaplimg.com, if this assists (I believe the last numbers 005 change randomly with server allocation).
traceroute to 17.253.48.225 (17.253.48.225), 64 hops max, 72 byte packets
1 dsldevice (192.168.1.254) 3.022 ms 2.576 ms 1.665 ms
2 lo0-central10.pcl-ag07.plus.net (195.166.128.188) 14.892 ms 15.334 ms 13.653 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.186) 13.338 ms 18.417 ms 13.334 ms
4 xe-9-0-0.pcl-cr02.plus.net (212.159.0.218) 14.049 ms 13.338 ms 13.283 ms
5 195.99.126.98 (195.99.126.98) 15.068 ms 14.249 ms 13.423 ms
6 core3-te0-10-0-21.faraday.ukcore.bt.net (109.159.249.141) 13.286 ms
core4-te0-0-0-27.faraday.ukcore.bt.net (109.159.249.185) 14.086 ms
core3-te0-0-0-21.faraday.ukcore.bt.net (109.159.249.171) 13.784 ms
7 host213-121-193-133.ukcore.bt.net (213.121.193.133) 14.210 ms 14.574 ms
peer6-te0-0-0-3.telehouse.ukcore.bt.net (194.72.31.87) 16.691 ms
8 166-49-211-240.eu.bt.net (166.49.211.240) 13.885 ms 13.725 ms 14.230 ms
9 166-49-211-254.eu.bt.net (166.49.211.254) 13.605 ms 14.682 ms 14.538 ms
10 ae5-xcr1.lsw.cw.net (195.2.28.25) 28.403 ms 27.457 ms 28.350 ms
11 ae8-xcr1.amd.cw.net (195.2.25.94) 21.297 ms 21.677 ms 45.683 ms
12 ae4-xcr1.fix.cw.net (195.2.28.30) 75.808 ms 27.697 ms 27.411 ms
13 * * *
14 * * *
15 defra1-vip-sx-005.aaplimg.com (17.253.48.225) 29.226 ms 28.894 ms 28.476 ms
13 * * *
14 * * *
Message 1 of 2
(548 Views)
1 REPLY 1
Re: Apple downloads slow
02-04-2015 5:58 PM
Hi g1000,
The routing of your connection can occasionally vary from that of BT or any of our other competitors . However if you were to try disconnecting and reconnecting and tracing again you may see a difference.
Message 2 of 2
(272 Views)
