Apple TV not Connecting
kenrob1000
Anyone had issues connecting Plusnet fibre to Apple tv? It sees the network, accepts password but won't connect. Worked fine with Sky.
mgraingerwifi
Re: Apple TV not Connecting
Hi, did you get any response or resolution to this issue? I'm having the same error now, Apple tv box worked fine with my old virgin media wifi
Fixes: 311
which router are you both using?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
