Apple Airport Extreme
- Apple Airport Extreme
26-06-2015 1:00 PM
My area has just been enabled for Fibre. Suggests download of about 55MBs an upload of 18MBs.
Currently I have 14 down and 1 up, so a significant speed difference, but it is fine for Flickr HD and everything else.
at present use an Apple Airport Extreme (wireless router) connected through a Draytex Vigor modem. Couple of Airport Express (extends wireless networks and streams music to hi fi) and 3 Apple TV.
All the stuff just works together, plays very nicely, and can be controlled from iPhones etc.
couple of questions,
is it worth moving to fibre?
if i do move to fibre, will my stuff continue to work?
thanks
Steve
thanks
Steve
Message 1 of 5
(890 Views)
4 REPLIES 4
Re: Apple Airport Extreme
26-06-2015 1:06 PM
Yes, just connect the Airport Extreme to the BT fibre modem instead of your Draytek modem, that's it!, simples!
Quote if i do move to fibre, will my stuff continue to work?
Message 2 of 5
(577 Views)
26-06-2015 1:08 PM
simply yes and yes
your extreme will work fine with the BT modem
Message 3 of 5
(577 Views)
26-06-2015 3:59 PM
thanks,
i like simple.
Steve
i like simple.
Steve
Message 4 of 5
(577 Views)
01-08-2015 1:50 PM
How are you getting on with your set up.....everything working as before but faster???
your set up is almost identical to mine.
dick:quote
dick:quote
Message 5 of 5
(577 Views)
