Appalling Product
- Re: Appalling Product
28-04-2021 5:26 PM
That report seems to suggest to me that there is some problem on the BTOR network, but I'm no telecomms engineer - just someone who has been on the 'net since 56k modem dial-up days. 😉
I don't know if either of them are about, but I'll tag @MisterW and @198kHz -and see if they have any thoughts - they both know more than me!
28-04-2021 5:52 PM
I would say there's still a line fault. As @jab1 says the downstream snr is too low. Also I would have expected a higher upstream syncbfor a line synching at 60Mb down.
@keithandrewowen what are your estimates from the BT wholesale checker https://www.broadbandchecker.btwholesale.com/#/AD
28-04-2021 6:10 PM
Do you mean the observed speeds?
Observed Speeds | VDSL |
Max Observed Downstream Speed | 60.85 |
Max Observed Upstream Speed | 6.46 |
Observed Date | 2021-04-28 |
What's confusing me is the wi-fi drops. The broadband connection does also drop a couple of times a day, although currently (at least according to the router itself) the DSL connection has been up for just over 6 hours. But the wi-fi drops maybe every 15-30 minutes. Why would this be?
28-04-2021 6:16 PM
No, Keith - @MisterW meant the whole of the report.
The Wi-Fi drops could be associated with the firmware version you have, which is why I tagged Bob Pullen earlier.
28-04-2021 6:27 PM
Sorry, I cannot post a screen capture because it times out every time I try to upload
28-04-2021 6:38 PM
That's a pity. You really have a wonky connection somewhere - even on my ADSL connection, much bigger screengrabs load with no problem.
on 28-04-2021 6:42 PM - last edited on 30-04-2021 8:22 PM by Mav
28-04-2021 6:50 PM
Thanks for that. Now I am really confused though - available says your range is 32-46, yet you are getting 61 (rounded).
Are you on Fibre or Fibre Extra?
28-04-2021 6:54 PM
Sorry, I'm on Unlimited Fibre Extra
28-04-2021 6:58 PM
28-04-2021 6:58 PM
You and me both, John. It's got to be a Fibre extra provision other wise it would be limited to 40Mb.
There's something not quite right here, there's no way it should be synching at 60Mb with those estimates!.
28-04-2021 7:03 PM
@keithandrewowen were you previously on Fibre with another ISP and have migrated to PlusNet ?
28-04-2021 7:12 PM
No, I had no previous provider. I've just returned to the UK after living for 21 years in Germany. I'm currently renting a place (pending a house purchase) and I chose Plusnet to provide internet and phone at the rental place. I have no idea what the previous tenants had in terms of phone or internet.
Regarding speed (quite apart from the instability issues) the speed of connection is very slow. Currently speedtest.net pegs it at 8.99/1.71
We are heavy internet users - in Germany we used no land-based phone/tv services, only Skype, streaming services, Netflix, Amazon Prime, DAZN, lots of Google Home devices
28-04-2021 7:22 PM
Thanks for that. It's almost as though the DLM parameters havent been reset with the new provision. Different routers can produce different speeds on the same line, depending on the chipset in both the router and the DSLAM. It's almost as though a previous router was more suited to the DSLAM and the parameters sunch as Target SNR had adjusted to that and not been reset to defaults when your provision happened.
Is that a wired or wireless test ?
The only test acceptable for raising a speed fault is a wired test using the BT wholesale checker.
There definitely something wrong with the line though and I think you have to persevere with raising a fault.
28-04-2021 7:32 PM
@keithandrewowen your router firmware has been upgraded to rule out any known Wi-Fi issues. you'll need to power the router off/back-on to apply the update.
