Anyone knows if Xiaomi AX3600 works with Plusnet Fibre? Thank you
Thank you for looking - not sure if this router will work with Plusnet so would like to check if anyone has success - it looks like there is no VLAN ID setting in their PPPOE page in their Chinese firmware though....
So if anyone can confirm this or the other way round that will be helpful.
Thanks a lot!
2 REPLIES 2
Fixes: 163
Re: Anyone knows if Xiaomi AX3600 works with Plusnet Fibre? Thank you
That's just a router, it has no built in modem. To use that you will need a separate VDSL modem, which will normally incorporate the VLAN ID setting.
Thank you, that answers my question. I was always using a modem router even with a 3rd party device...will try linking the modem with the router and see if that works.
Thanks a lot!
