Anyone able to tweak me? :P
- Anyone able to tweak me? :P
05-02-2015 2:31 PM
LtBrenton
Re: Anyone able to tweak me? :P
05-02-2015 2:38 PM
05-02-2015 2:44 PM
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
The profile on our side is set correctly too.
Can you try a BT speedtest at http://speedtest.btwholesale.com/ and then do the 'further diagnostics' test after the first results. Let us know the results that shows.
05-02-2015 3:13 PM
"Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information. "
With no such results appearing on the page. I'm suspecting that may be down to dodgy web code, however it does render the test rather unhelpful...
05-02-2015 3:17 PM
05-02-2015 3:21 PM
05-02-2015 3:29 PM
05-02-2015 3:30 PM
05-02-2015 3:31 PM
05-02-2015 3:36 PM
05-02-2015 3:46 PM
05-02-2015 3:49 PM
05-02-2015 4:03 PM
05-02-2015 4:17 PM
06-02-2015 9:57 AM
http://www.plus.net/support/broadband/bbfaults/
