Any other Fibre availability checker?
- Re: Any other Fibre availability checker?
05-05-2015 8:03 PM
We have recently had our very first cabinet installed in our village as we were previously all on Exchange Only lines and with a FTTC install date by the OpenReach Coming Soon PDF of March they have also put in place along side the larger fibre cab
I've been checking using the BT DSL Checker and also DigitalScotland and Superfast website but I've been forever stuck at Coming Soon
The output from the DSL checker is attached as well as my current router sync rates
My queries are therefore if there is any other checker to give me more information as when I should expect to be able to place an order and also going by my current sync if I should be hopeful to get good speeds with the upgrade?
I'm currently syncing what looks like at the maximum (8Mb) but as of this post only able to pull around 2Mb down
Thanks,
Martin
Thanks,
Martin
Message 1 of 8
(905 Views)
7 REPLIES 7
05-05-2015 8:34 PM
Have you checked the IP profile and the Current Line Speed (see my sig for that one)
Message 2 of 8
(584 Views)
05-05-2015 8:50 PM
Telephone number:<Removed>
Phone exchange:
ROTHIENORMAN
Estimated line speed:
8Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-05-04 13:40:18
Current line speed:
7.15 Mb
Phone exchange:
ROTHIENORMAN
Current line speed:
7.15 Mb
Message 3 of 8
(584 Views)
05-05-2015 8:54 PM
Are you using a wired or a wireless connection to the router?
Message 4 of 8
(584 Views)
05-05-2015 9:16 PM
Wired
The attached results and link below are all from a wired connection
http://www.speedtest.net/my-result/4339513682
Message 5 of 8
(584 Views)
05-05-2015 9:25 PM
Usually means due by the end of that month.
Message 6 of 8
(584 Views)
05-05-2015 9:27 PM
Ah is that from the coming soon PDF?
It must have updated as it previously said March
Cheers!
Cheers!
Message 7 of 8
(584 Views)
05-05-2015 9:32 PM
They've stopped updating that one (it became very misleading!) - I've got an internal one, but again it's subject to change.
The good thing is that you have the cabinet in place and the handover exchange (Turriff) is already set up. It's a BDUK funded cab and these seem to be a priority at the moment.
Message 8 of 8
(584 Views)
