Any fibre problems around Morpeth, NE? My speed has halved from 45 to 23...
Casey
Connected at 46xxx according to "helpdesk" but all the speed testers show 22-23 rather than the 44-45 I've had since joining. anyone know of any probs up here? Something to worry about or is it gonna be fixed?
Casey
Interesting
Interesting - I have been told not to reset the hub or turn it off unless absolutely needed - it causes the line profiler to think there's a fault and to limit speeds.
But - I told the hub to reset through the browser interface.
about 2 mins later it was back online and connected at 47 (in "helpdesk") with a 43-44 speedtest result.
Now the question is - WHY was it so low before the reset?
Andrue
Re: Interesting
Yes, it might. If you reset it or power cycle it it will drop the VDSL connection and the cabinet will wonder if there's a fault. It's okay to do it once but do it too many times in too short a period and the cabinet will start reduce your connection speed in an attempt to resolve what it sees as an unstable line. This has been a feature of BT's VDSL (and indeed ADSL) for many years now. It's what's referred to as 'DLM' - Dynamic Line Management.
Those of us with separate modem/router have less of a problem because we can do what we want with our routers as long as we leave the modem alone.
Possibly you were on a different IP address (there seems to be a problem with 51.* at the moment). Your reset may have triggered a change to a better address.
Casey
Re: Interesting
Interesting.
The reset (just "reset hub") fixed it... but I was already on a 87.1xxx IP, still on 87.115.
Weird.
