Any chance of Fastpath - stats are good
snadge
Fixes: 6
so for over 1 year my MAX ATTAINATBLE RATE has been almost 80Mb but my sync is 66.8Mb and profile must be 60Mbps cos I can't get more than 56Mbps on many tests
this tells me there a stuck profile issue and yes I've tried rebooting daily and its still the same
also, it is the opinion of BTo Engineers that error seconds have to stay 3 or below per hour to enable fastpath..well according to DSL-stats 6.5.9 I'm getting 1 on average per hour : see :-
DSLAM type / SW version:    IFTN:0xb206 (178.6) / v0xb206Modem/router firmware:      AnnexA version - A2pv6F039v.d26a
DSL mode:                   VDSL2 Profile 17a
Status:                     Showtime
Uptime:                     5 days 20 hours 6 min 9 sec
Resyncs:                    0 (since 17 Feb 2021 09:47:13)
                Downstream    Upstream
Line attenuation (dB):      14.1        0.0
Signal attenuation (dB):    Not available on VDSL2
Max: Upstream rate = 24235 Kbps, Downstream rate = 78498 Kbps
Connection speed (kbps):    20000 Kbps       65820 Kbps
SNR margin (dB):            6.1        9.1
Power (dBm):                4.0        4.0
Interleave depth:           1289        1
INP:                        3.00        0
G.INP:                      Not enabled        Not enabled
Vectoring status:           5 (VECT_UNCONFIGURED)
RSCorr/RS (%):              0.0222        0.0298
RSUnCorr/RS (%):            0.0003        0.0000
ES/hour:                    0        2.00
as you can see less than 0.02% of my traffic is corrected and 0.0003% couldn't be corrected (and new request sent)
the low ES/per hour should allow me to use Fastpath, is any chance we can try it as I'm a gamer
cheers
2 REPLIES 2
ChrisFox
Re: Any chance of Fastpath - stats are good
I'm in a similar boat, and as I understand it Plusnet have pretty limited tools to influence it - it's largely applied by Openreach's DLM. Their answer will probably be that it's working as intended. In theory, given a stable enough connection, DLM should eventually reverse it itself but how long it needs a stable line to do so is a bit of a dark art: https://kitz.co.uk/adsl/DLM.htm
For what it's worth, rebooting the router daily might be doing more harm than good if DLM is interpreting them as dropped connections?
RichardB
Champion
Fixes: 33
Hi @snadge
I agree with @ChrisFox dropping the synch daily will likely confuse DLM.
DLM will regard the disconnections as line instability.
Far better to leave the router in synch for as long as possible.
Regards
Richard
