Any chance of Fastpath - stats are good
- Any chance of Fastpath - stats are good
17-02-2021 10:21 AM - edited 17-02-2021 10:29 AM
so for over 1 year my MAX ATTAINATBLE RATE has been almost 80Mb but my sync is 66.8Mb and profile must be 60Mbps cos I can't get more than 56Mbps on many tests
this tells me there a stuck profile issue and yes I've tried rebooting daily and its still the same
also, it is the opinion of BTo Engineers that error seconds have to stay 3 or below per hour to enable fastpath..well according to DSL-stats 6.5.9 I'm getting 1 on average per hour : see :-
DSLAM type / SW version: IFTN:0xb206 (178.6) / v0xb206Modem/router firmware: AnnexA version - A2pv6F039v.d26a
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 5 days 20 hours 6 min 9 sec
Resyncs: 0 (since 17 Feb 2021 09:47:13)
Downstream Upstream
Line attenuation (dB): 14.1 0.0
Signal attenuation (dB): Not available on VDSL2
Max: Upstream rate = 24235 Kbps, Downstream rate = 78498 Kbps
Connection speed (kbps): 20000 Kbps 65820 Kbps
SNR margin (dB): 6.1 9.1
Power (dBm): 4.0 4.0
Interleave depth: 1289 1
INP: 3.00 0
G.INP: Not enabled Not enabled
Vectoring status: 5 (VECT_UNCONFIGURED)
RSCorr/RS (%): 0.0222 0.0298
RSUnCorr/RS (%): 0.0003 0.0000
ES/hour: 0 2.00
as you can see less than 0.02% of my traffic is corrected and 0.0003% couldn't be corrected (and new request sent)
the low ES/per hour should allow me to use Fastpath, is any chance we can try it as I'm a gamer
cheers
Re: Any chance of Fastpath - stats are good
17-02-2021 10:48 AM
I'm in a similar boat, and as I understand it Plusnet have pretty limited tools to influence it - it's largely applied by Openreach's DLM. Their answer will probably be that it's working as intended. In theory, given a stable enough connection, DLM should eventually reverse it itself but how long it needs a stable line to do so is a bit of a dark art: https://kitz.co.uk/adsl/DLM.htm
For what it's worth, rebooting the router daily might be doing more harm than good if DLM is interpreting them as dropped connections?
17-02-2021 11:23 AM
