Any capacity issues?
- Any capacity issues?
Re: Any capacity issues?
10-01-2015 4:07 PM
jim:quote
10-01-2015 4:15 PM
But today got this speed at 3:50pm
10-01-2015 4:56 PM
Could someone else have been using the internet when you ran the test today?
10-01-2015 5:06 PM
10-01-2015 5:09 PM
I would run the test again to see what kind of result you get. Sometimes you can get strange looking results because a process on your PC/Mac is using a lot of memory/processing capacity.
10-01-2015 5:14 PM
10-01-2015 5:17 PM
11-01-2015 1:57 PM
The issues I reported are verifiable, repeatable and easily observable. They are notable via the TBB BQM and tests via TBB, Namesco and BT Wholesale; they reoccur at peak times every evening to varying degrees, and issues are noted via both wired and wireless machines running different operating systems.
If there are issues that don't seem to conform to these it might be best for peeps to make new threads for their own issues as they may well not be the same.
CrystalJayme your issues are not the same - you do not have the really big difference between TBB 1x and 6x I see, no packet loss to speak of, no average or periodic increase at peak times, and it's impossible to prove your own home network out as you're using WiFii to connect to homeplugs to connect to your router - there's way too much there to go wrong before it touches the Openreach kit. There's potential for interference both on your own home power circuits, more appliances being used at that time, and across the airwaves on the WiFi.
If you're still seeing issues a new thread would probably be the best way forward to avoid ongoing issues getting lost in this one.
11-01-2015 6:49 PM
11-01-2015 7:13 PM
Me and andyh know enough that obviously we testing on ethernet cables, and ruled out local equipment hence why we are also in this thread.
11-01-2015 9:41 PM
this started at around 8pm which corralates to a certain degree with the increase in Broadband bandwidth usage graphs http://www.plus.net/support/service/network_performance/broadband_bandwidth_usage.shtml#totalTraffic
so maybe something related to plusnet ?? if this keeps on happening i may have to bite the zen bullet now that i'm out of contract
I have just looked at the ping monitors for plusnet customers and i don't like what i can see on some of them
11-01-2015 9:48 PM
Quote from: Melancholie This. Friday isn't a busy day. Sunday and Monday will suck.
As anticipated.
Download speed achieved during the test was - 17.78 Mbps
For your connection, the acceptable range of speeds is 52.1 Mbps-65.12 Mbps .
Additional Information:
IP Profile for your line is - 65.12 Mbps
11-01-2015 10:34 PM
Quote from: deathtrap Well tonight my thoughput is severely affected Even downloads 5 threads are only giving around 30mbps this is not good for fttc and i'm seeing the low level packet loss again tonight will post my Ping monitor later
The graphs are interesting.
Faraday appears to be flatlining as does colindale.maybe, but it isnt conclusive, doesnt look like a normal flatline, could just be how its panned out.
11-01-2015 10:46 PM
If this isn't a capacity issue peering or network then it must have something to do with something malfunctioning when the total traffic reaches a certain level or it's good old fashioned throttling
11-01-2015 11:05 PM
Simply Plusnet need to assure us that they are not the bottleneck here, then the onus goes onto BT Wholesale.
Openreach, the last link in the chain, are most definitely not the issue.
I'm pretty sure Plusnet's network is busy, that I've been moved around a bit recently implies it, however Plusnet manage their network and I'm seeing issues with traffic that should be a high priority so I'm not inclined to blame them.
I reckon BT Wholesale's SVLAN report is wrong, nothing more arcane than that.
