Any capacity issues?
- Any capacity issues?
Re: Any capacity issues?
05-01-2015 8:18 AM
05-01-2015 8:37 AM
Quote from: chrcoluk Guys how do you know which SVLAN you on and where can I check SVLAN status? As Andy will claim he hasnt got inside info
You need one of the PN guys to tell you which SVLAN you're on. I don't think there's any other way of finding out.
As for the status, you need an ISP contact to either tell you whether it's green/blue/yellow/red.
05-01-2015 8:44 AM
05-01-2015 8:59 AM
However, I have noticed a second BT 'green' box where there used to be only one - fitted before xmas.
05-01-2015 9:07 AM
05-01-2015 9:11 AM
No idea what it is or whether it is good or bad.
05-01-2015 9:37 AM
http://www.robertos.me.uk/html/street_cabinets_etc.html
05-01-2015 9:59 AM
Quote from: Melancholie Hi Andy,
Hunslet - SVLAN SFBB00005266
All are apparently green.
Thanks, interestingly not being picked up by BTW. Sometimes I've seen this though where you have a 'parent' SVLAN and that has capacity problems, even though your SVLAN is showing as fine.
I think mine is being picked up by BTW, just waiting on confirmation of which SVLAN I am on (also raised a ticket - 97181192).
05-01-2015 10:08 AM
Quote from: AndyH
ok thanks.
05-01-2015 10:17 AM
Quote from: Melancholie Okay sounds like it's for something else in that case.
The new one is on the left. (A BT engineer was working in the one on the right, hence the picture of the back side.).
05-01-2015 10:21 AM
05-01-2015 10:26 AM
Quote from: AndyH Thanks, interestingly not being picked up by BTW. Sometimes I've seen this though where you have a 'parent' SVLAN and that has capacity problems, even though your SVLAN is showing as fine.
Hiya,
Indeed. It's not impossible that capacity issues aren't with the SVLAN but with the Ethernet bearer it lives on, or deeper into the network right up to and including the BRAS.
It may also have been tipped over by Christmas and be amber in the next report
05-01-2015 2:20 PM
BT Wholesale – Network – Planned Engineering Work(PEW)Notification – PW247679 Standard – 27/01/2015 00:01 – Leeds Basinghall – software and hardware upgrade – (MID 19774894) – EU outage of up to 1 Hours
My connection goes via bras-red11.ls-bas - Redback 11, Leeds Basinghall.
05-01-2015 4:46 PM
06-01-2015 6:04 PM
I suspect it's load however the BT Wholesale systems haven't spotted it yet.
Either way the impact isn't too scary as of yesterday so will sit back and keep an eye on it.
