Another request for my radius graph please.
- Re: Another request for my radius graph please.
02-01-2017 11:06 AM
Just what the subject says really can I have it for the .41 IP please. I've noticed that my fibre connections have both reduced in speed over the past few days, and that the .41 interface seems to be dropping to often for my liking.
02-01-2017 11:47 AM
It doesn't look pretty:
02-01-2017 12:23 PM
Thanks for that @Chris, could this :
Results Image not loaded 1. Best Effort Test: Download Speed : 53.27 Mbps 2. Upstream Test: Upload Speed : 11.93 Mbps Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
And the above graph result be indicative of a fault?
02-01-2017 12:46 PM
It would certainly appear so. Out of interest, are you uploading a lot through that circuit when the disconnections are happening?
02-01-2017 12:59 PM
No @Chris, I'm not, it's used as the failover for WAN 1 and I route my Mac out of it as well so it doesn't really get much load. It's had yet another disconnect / reconnect since my OP, and in the just over an hour of uptime it's moved 590MB with most on the RX.
02-01-2017 1:01 PM
Get it reported at https://faults.plus.net and we'll pick it up asap
02-01-2017 1:16 PM
@Chris, done and thanks for your time.
03-01-2017 1:39 PM
Can someone maybe explain why the ticket raised (above) isn’t due a response until the 5th when the ticket shows that there is in fact a fault? I have a remote VPN connection on this wire and as I go back to work tomorrow it will no doubt be pressed in to service but I can’t have it getting dropped as often as it is.
So your thoughts on this would be appreciated.
03-01-2017 1:46 PM
The fault troubleshooter has reported this through to BTWholesale automatically, so the ticket is put on hold to allow a response from them. Having just checked this, we've now received a response and it's requesting an engineer visit.
I'll update the ticket with that info now.
03-01-2017 1:59 PM
Thanks again @Chris, ticket replied to.
03-01-2017 2:24 PM
Booked and updated on the ticket, that's the earliest one available so I hope it's ok.
03-01-2017 2:54 PM
That's fine by me @Chris so thanks yet again, and the service excellent as always.
05-01-2017 4:31 PM
Well a very helpful BTOR guy arrived this morning at the CoD and after 2 hours of diagnostics and broggling it was traced to an underground fault. Sadly he couldn’t fix it himself as he didn’t have the training but raised it internally to get fixed.
By coincidence one of my neighbours came over when she saw the BTOR van asking if I had issues with my service as hers was as dead as a dead thing could be dead and had been since Thursday, which just happened to be the same time that mine fell over although my continued to work but at a reduced rate.
Don’t know when the BTOR UG team are going to arrive but I hope it’s soon.
