Another disgruntled customer.
- Re: Another disgruntled customer.
07-10-2015 1:17 PM
Yep I was sooo happy, did the fault finding stuff, followed procedure, engineer calls to check equipment all good, "its the distance you are from the exchange" he tells me, this is as good as you'll get. Back on the phone to plusnet, customer services > technical>customer services+(whatever the term is) To be told;
I must wait for ten days(didn't think this applied to fibre from what I have read on this forum), I mustn't stress over the speed tests, I could expect wild fluctuations, (.4Mb from all the tests I've done) Plusnet have spent hundreds getting fibre too me and lastly at least I have a nice view out of my window!!!!
I know I was offered £1.50 off my bill, which is high anyway being area1 or I could go back too ADSL, that is not really the point (although it feels like Hobson's choice).
When I took out the service I was told the estimates given were pretty accurate, and I had no way of knowing otherwise, (all the checks I have done since all showed a similar figure) I just feel let down, frustrated and really p****d off at the comments I got, and the "well that's what you get for living in the countryside attitude." Sorry for the rant I had to get this off my chest, it might seem small beer to some, but I had to vent my spleen!!
07-10-2015 1:20 PM
edit: nicked the following from Terranova667 in a similar thread:
Quote from: Terranova667 Ok go here http://speedtest.btwholesale.com/ and run the speed test ignore the red writing, when it's done pick further diagnostic and post the results
also go here https://portal.plus.net/my.html?action=data_transfer_speed login and see what the current line speed is set to again post the results
we will be able to see if they are set correctly
07-10-2015 1:33 PM
1. Best Effort Test: -provides background information.
Download Speed
3.24 Mbps
0 Mbps 4.36 Mbps
Max Achievable Speed
Download speedachieved during the test was - 3.24 Mbps
For your connection, the acceptable range of speedsis 3.05 Mbps-4.36 Mbps .
Additional Information:
IP Profile for your line is - 4.36 Mbps
Upload Speed
1.06 Mbps
0 Mbps 2 Mbps
Upload speed achieved during the test was - 1.06Mbps
Upstream Rate IP profile on your line is - 2 Mbps
Phone exchange:
SOUTHREPPS
Estimated line speed:
9Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-10-07 13:00:32
Current line speed:
3.3Mb
They look like the results I have been getting since it was set up.
07-10-2015 2:42 PM
0 Mbps 4.36 Mbps
when I last ran the BTW checker this information was not available.
07-10-2015 2:49 PM
07-10-2015 3:18 PM
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High Low High Low
FTTC Range A (Clean) 15.5 9.2 1.2 0.8 -- Available
07-10-2015 4:34 PM
07-10-2015 4:49 PM
SOUTHREPPS
Current line speed:
4.3 Mb
07-10-2015 4:57 PM
07-10-2015 5:04 PM
These haven't been bought up by anyone though, the engineer who came round this morning, thought the line was clean from what I told him the ADSL figure were previously.
07-10-2015 5:10 PM
In my case I am in the impacted range due to lead sheathed cable to my local DP (Distribution Point) from the cab
Notwithstanding the above you and Plusnet should persevere and try to get it sorted. One thing which may be possible is trying a different pair from the cab to the DP
07-10-2015 5:42 PM
Tbh as soon as I told the tech team that the BT engineer said its as good as you'll get, they kinda dropped the ball pretty quickly, I'm no expert on any of these matters and I do rely on people giving me fair an honest advice and hope they are doing what's best for me as a customer, I was never told about swapping lines, in fact I was given no other alternatives, it shouldn't be like this, it really shouldn't. I'm not asking for the earth, just an honest assessment of what is truly available after ALL options have been explored. It is difficult to ask for something if you don't know that something exists! I thank you for giving me some input into the situation, and will approach PN again with this idea, and... anything else they can think of.
PN I hope you read this and comment!
