Amber power & red Broadband
FIXED- Subscribe to RSS Feed
- Re: Amber power & red Broadband
08-03-2019 3:49 PM
08-03-2019 4:58 PM
08-03-2019 5:17 PM
08-03-2019 5:32 PM
08-03-2019 11:22 PM
30 hrs later on it's on the move...
5. DSL uptime: | 1 days, 06:09:03 |
6. Data rate: | 1688 / 19421 |
7. Maximum data rate: | 1755 / 22477 |
8. Noise margin: | 7.7 / 6.2 |
Obviously not enough to grab the phone yet, just pointing out that its moving
Speed at:
11:01 - https://www.thinkbroadband.com/speedtest/1552042896417678055
17:59 - https://www.thinkbroadband.com/speedtest/1552067973574032755
23:19 (very low d/l and u/l) - https://www.thinkbroadband.com/speedtest/1552067973574032755
09-03-2019 12:18 PM - edited 09-03-2019 12:42 PM
There is definitely a pattern, but I have no idea what/where it is!!
So, after my excitement the other day, we all know I messed up and pulled the DSL, which generated
17:07:10, 07 Mar. | (1199131.990000) PTM over DSL is up |
17:06:38, 07 Mar. | (1199099.940000) PTM over DSL is down after 1679 minutes uptime |
17:06:38, 07 Mar. | (1199099.940000) PPPoE is down after 1678 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)] |
17:06:35, 07 Mar. | (1199096.940000) PPP LCP Send Termination Request [User request] |
Now this one wasn't me!!
Going right back, it's the same darn WAN Eth 7 every time!!!!!!
02:28:17, 09 Mar. | (1319195.970000) PTM over DSL is up |
02:27:44, 09 Mar. | (1319162.940000) PTM over DSL is down after 2000 minutes uptime |
02:27:44, 09 Mar. | (1319162.930000) PPPoE is down after 1999 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)] |
02:27:41, 09 Mar. | (1319159.820000) PPP LCP Send Termination Request [User request] |
The SNR, at the time of posting, is.....
5. DSL uptime: | 0 days, 09:41:55 |
6. Data rate: | 2848 / 23222 |
7. Maximum data rate: | 2898 / 22905 |
8. Noise margin: | 6.4 / 6.0 |
Does anyone know where 'it' is? I think it's either a card in the exchange or a break in a cable, what else is there...?
All drops, whether it's pulling the DSL cable out (a physical break in the circuit) or 'out there, some where' does the same event.
SWMBO and MIL been chatting a few mo's ago, nothing heard as yet.
edit. So yesterday it was raining and the router went for 30+ hours before the SNR started dropping. Now after posting the above, the SNR has dropped after 10hrs!
5. DSL uptime: | 0 days, 10:08:15 |
7. Maximum data rate: | 2658 / 22391 |
8. Noise margin: | 4.6 / 5.9 |
So did the rain 'help' by making an underground connection better as atm it's sunny (and windy - but don't think that matters).
Probably overthinking this.....?
09-03-2019 2:01 PM - edited 09-03-2019 2:38 PM
Here's the state of play atm....
One cordless BT Diverse 7150 (need this due to disabilities) does hear static very noticeably
One Binatone Concept Combo 3505 (using corded) also hears this, but it is very quiet (don't recommend as mic is ___ - rhymes with mic)
One Southern Telecom EM2116WH corded phone also hears it, again it is very quiet
Currently have someone fetching another new phone (so this = 3 new phones), a BT Duet 210 and will give results in due course.
With any of the above, obviously not the 210 yet, the SNR does not budge....
currently
5. DSL uptime: | 0 days, 11:31:44 |
7. Maximum data rate: | 2708 / 22454 |
8. Noise margin: | 4.8 / 5.9 |
The only reason for yet another phone is to rule out the 2 cheap ones above
edit 1 of ?
Within a few mins of after the last 17070 was tried, the SNR has dropped
5. DSL uptime: | 0 days, 11:51:42 |
7. Maximum data rate: | 2450 / 22438 |
8. Noise margin: | 4.0 / 5.9 |
(further testing is a thought to see if it continues to drop after hanging up)
edit 2 of?
Hmm, right, weird. When using the 17070 opt 2 (QLT) facility, during the quiet times my max data rate on the d/s increases every time I mash the F5 button. When she says "quiet line test" the max data rate decreases. Checked this multiple times and it the same every time. This is blowing my mind!!
09-03-2019 3:48 PM
One cordless BT Diverse 7150 ... does hear static very noticeably
The speaker for this phone is just behind the plastic moulding and three persons have now heard the same noise, it's not as loud as earlier, but it is there.
Currently have ... a BT Duet 210
Not sure how close the speaker is to the moulding as the 'ear end' is deeper than the rest of the phone. Again 3 persons have heard* a faint static/whoosh/something type sound. When all 3 agreed, the receiver was replaced and oddly the phone rang! This could be as it was it's first use as now it no longer rings when you end the call to 17070.
*albeit 1 of us could hardly hear it.
The 'results' from the hub, taken 5mins after the 'test' are:
5. DSL uptime: | 0 days, 13:17:16 |
7. Maximum data rate: | 2640 / 22817 |
8. Noise margin: | 4.5 / 6.0 |
As it's quieter than early, what do I do now ..... wait .... report .... live with it ..... try when/if the SNR drops to less the 3dB ?
10-03-2019 3:11 PM
2052 on 07.03.19
5. DSL uptime: 0 days, 03:45:16
6. Data rate: 1688 / 19421
7. Maximum data rate: 2124 / 22182
8. Noise margin: 9.6 / 6.1
9. Line attenuation: 30.5 / 28.4
10. Signal attenuation: 30.0 / 24.0
5. DSL uptime: 0 days, 08:21:25
7. Maximum data rate: 2120 / 22760
8. Noise margin: 9.6 / 6.4
1101 on 08.03.19
7. Maximum data rate: 1822 / 22919
8. Noise margin: 8.0 / 6.5
10. Signal attenuation: 29.9 / 24.0
5. DSL uptime: 0 days, 18:39:40
7. Maximum data rate: 1818 / 22803
8. Noise margin: 7.9 / 6.5
1326 on 09.03.19
5. DSL uptime: 0 days, 10:58:28
6. Data rate: 2848 / 23222
7. Maximum data rate: 2755 / 22486
8. Noise margin: 4.9 / 5.9
9. Line attenuation: 30.6 / 28.3
10. Signal attenuation: 30.5 / 24.0
A rather odd TBB result at 17:52
https://www.thinkbroadband.com/speedtest/1552153963642957055
1842
5. DSL uptime: 0 days, 16:13:48
7. Maximum data rate: 2482 / 22482
8. Noise margin: 4.0 / 5.8
Pressed F5 several times and the up SNR was 4.0, it then jumped
1853
5. DSL uptime: 0 days, 16:25:16
7. Maximum data rate: 2884 / 22538
8. Noise margin: 6.1 / 5.9
Better result on TBB at 19:30
https://www.thinkbroadband.com/speedtest/1552159855264809755
It stayed around 6dB, then dropped again
1959
5. DSL uptime: 0 days, 17:31:30
7. Maximum data rate: 2690 / 22415
8. Noise margin: 4.5 / 5.9
10. Signal attenuation: 30.6 / 24.0
20:08 and SNR up again, nothing done/tested
5. DSL uptime: 0 days, 17:41:14
7. Maximum data rate: 2941 / 22359
8. Noise margin: 6.6 / 5.8
10. Signal attenuation: 30.3 / 24.0
d/s SNR was 3.9dB around 10pm, tried 17070, faint noise, within 5 mins SNR back to 5.4dB
2254
5. DSL uptime: 0 days, 20:26:22
7. Maximum data rate: 2891 / 22638
8. Noise margin: 6.3 / 6.0
10. Signal attenuation: 30.4 / 24.0
2310
https://www.thinkbroadband.com/speedtest/1552173033386147855
0138 on 10.03.19
(it tried to run but tripped at the start)
https://www.thinkbroadband.com/speedtest/1552181930772036155
1153 on 10.03.19
5. DSL uptime: 1 days, 09:26:30
7. Maximum data rate: 2428 / 22554
8. Noise margin: 3.8 / 5.9
17070 , opt 2 gives a very faint noise using Decor 210 (only used this one this time)
recheck stats and
5. DSL uptime: 1 days, 09:28:18
7. Maximum data rate: 2432 / 22466
8. Noise margin: 3.6 / 5.8
So, how quiet should it be, totally silent or a little noise is to be expected....?
(is it my Super Man hearing, or SWMBO's I've listened to too much loud music over the years coz she hardly hears it)
Pondering, scratching, pondering some more and no doubt further testing req'd
10-03-2019 8:30 PM - edited 10-03-2019 8:33 PM
Another false start at 16:51 https://www.thinkbroadband.com/speedtest/1552236664457061955
2 hours later at 17:50 https://www.thinkbroadband.com/speedtest/1552240214845754355
Another 2 hours (just over) at 19:58 https://www.thinkbroadband.com/speedtest/1552247887388083155
Both the up and down SNR have frozen for some time now at:
Noise margin: | 5.7 / 5.7 |
(new one on me)
Data rate higher than max rate, can't recall noticing this before and there's no way I'm trawling through all this to check! Ok, so I looked
Maximum data rate: | 2834 / 22598 |
10-03-2019 11:10 PM - edited 10-03-2019 11:38 PM
So, since around 19:30 the SNR both up and down has remained constant at:
5. DSL uptime: | 1 days, 20:33:31 |
7. Maximum data rate: | 2848 / 22650 |
8. Noise margin: | 5.7 / 5.7 |
Whilst checking this, every 10 mins or so, this is the first and only time (IIRC) that it's not moved at all !!
The upload data rate hasn't moved either !!
Nothing has moved or changed during this time here, the laptop is still (annoyingly) via ethernet, so what the heck has caused the SNR to settle perfectly?
Baffled is I
edit.
If all of this has been caused by a buggy firmware, then I'll hit the roof!!
If this continues then ignore the above sentence
What's all this....?
Okay, so it did the usual handshake
20:19:51, 09 Mar. | (1383487.050000) CWMP: Initializing transaction for event code 2 PERIODIC |
The handshake was accepted
20:19:55, 10 Mar. | (1469889.140000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo |
Oh, a gift, for me?
20:19:55, 10 Mar. | (1469889.340000) CWMP: Download file, FileType=1, FileName=bt_signed_prod_secured.enc.rms, Username=, CommandKey=<redacted> |
But I don't want it, though it insists
20:19:55, 10 Mar. | (1469889.590000) CWMP: Initializing transaction for event code 6 CONNECTION REQUEST |
I still didn't want it, but it put it in my hand
20:20:21, 10 Mar. | (1469915.140000) CWMP: Download status=OK |
I sign for it and you give me the counterpart
20:20:21, 10 Mar. | (1469915.610000) transfer completed successfully |
Is this a new product from Ron McDo?
20:20:21, 10 Mar. | (1469915.610000) CWMP: Initializing transaction for event code M Download |
Whatever it is, I can't give it back
20:20:22, 10 Mar. | (1469916.090000) CWMP: Session start now. Event code(s): '7 TRANSFER COMPLETE,M Download,4 VALUE CHANGE' |
So, unless I'm mistaken nowt changed but you updated it.....?
Software version 4.7.5.1.83.8.259 | Last updated 10/03/19
11-03-2019 9:54 AM
My excitement was short lived....
04:00:01, 11 Mar. | ( 80.480000) PTM over DSL is up |
03:59:19, 11 Mar. | ( 38.280000) WAN Auto-sensing running. |
03:58:10, 11 Mar. | (1497384.370000) PTM over DSL is down after 2969 minutes uptime |
03:58:10, 11 Mar. | (1497384.370000) PPPoE is down after 2968 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 7 - Down)] |
03:58:07, 11 Mar. | (1497381.280000) PPP LCP Send Termination Request [User request] |
Though the auto sensing running is a new one on me, I think...?
11-03-2019 4:29 PM - edited 11-03-2019 5:30 PM
Bit lost for words tbh, can't get my head around this.
So I get the update at 20:20 on the 10 March, but the drop earlier (at 03:58 on 11 March) applied the update.
At least I found the reason for the auto wan sensing
Why the delay? Should it have not updated there and then?
As of (just checked) now, I too am now on the 4.7.5.1.83.8.263 firmware. The only way I noticed was that the data sent and received had reset.
The down side to the new f/w ... the SNR has moved .... again!!
edited wrong post, my bad
11-03-2019 4:52 PM
Thanks for the update, @DS
I'm honestly not sure why the update would be delayed after it hit your router (or if indeed it should be at all). My colleague @bobpullen may be able to shed some light on this.
In terms of the SnR margin, this probably will happen when there's a drop in connection (artificial or otherwise) and I'd expect to see that level out over time. How are things looking with the connection in general? Has the firmware update helped at all? I've checked your connection from our side and it's looking relatively stable at present.
Best wishes
Dave
11-03-2019 5:10 PM - edited 11-03-2019 5:32 PM
Thanks for that
I do believe it should have updated as soon as it hit the router, but I'm happy to be corrected on that
After receiving the file the SNR was pretty stable (at 5.7) but after the update took place it started moving again. Is there a relationship to this? Perhaps....?
Tis finding why it's going off that's muchas difficultas
Its hard to know how it is atm, though unhappy to report SWMBO commented that her phone was saying 'poor internet connection, please check your internet' this morning .... <sigh> but I now know it's AFTER the f/w update and she's never had it before!! And that's on the 2.4GHz
The router hasn't really been 'worked hard' as yet, though IDK for certain as the forums have been hit n miss today.
No doubt I'll update at some point....
edit Eh, the forums are jumping to wrong post
Erm, something else is 'seeing' the new f/w, our smart TV (near the router, fixed to the wall, nothing moved, but on 2.4GHz) has always had full signal - always!! It's now reporting a weaker signal
Hope this isn't one step forward and two back ...
Guess I need to 'monitor' this now too
