Am i getting what i signed up for ??
Lee83
I signed up for fibre extra ,which advertised estimated download of 40 to 54mgbs and estimated upload of 7 to 10 mgbs ,but im on a constant 38 down and 1.75 up is this correct ,any help would be appreciated
10 REPLIES 10
Lee83
Re: Right fibre package ??
I ment unlimited fibre extra
Lee83
The download is close but the upload is way off
Chris
Legend
Fixes: 169
Re: Am i getting what i signed up for ??
It looks like the order had been placed incorrectly. I'll get that fixed and you should see the improvement from tomorrow, sorry about that.
Lee83
Thanks chris
Lee83
Can you confirm for defo that the order was placed incorrectly and if its been rectified
MatthewWheeler
Fixes: 479
The order completed this morning so you should be seeing higher speeds.
 Matthew Wheeler
Lee83
Brilliant , il check when i get home ,thank you Matthew
Lee83
Sorted , brilliant quick and easy , thanks guys
MatthewWheeler
Fixes: 479
Glad to hear it!
 Matthew Wheeler
Mav
Fixes: 515
Moderator's note by Mike (Mav): I have changed the fix to Chris as per message #4
Forum Moderator and Customer
