Am I wasting money on "EXTRA"
- Re: Am I wasting money on "EXTRA"
- « Previous
- 1
- 2
- Next »
06-05-2015 1:02 PM
An update on my question. After help from PlusNet I found that the engineer who installed my Fibre had not done the job properly. He had told me my existing 12m phone extension lead was OK and after tests it was shown that was the cause of slow speeds. I got a £10 refund and advice to connect my modem to my router by an RJ45 cable. I did this today but the speed is unchanged. I have raised the matter with PlusNet as I hadn't closed my question, but I wondered if anyone here could say when I might see my estimated speed which is around 66?
Message 16 of 20
(375 Views)
06-05-2015 1:50 PM
What is the IP Profile reported when you run the BT diagnostic speed test?
Message 17 of 20
(375 Views)
06-05-2015 2:46 PM
Message 18 of 20
(375 Views)
06-05-2015 3:10 PM
Quote from: Matthew If you log into your router and disconnect then reconnect you should get a increase in speeds.
Done that.....
Thanks.
Speed on Speedtest.net now 53.94 and 16.13.
I was told to expect around 66 minimum.
Is a further increase likely with use?
Message 19 of 20
(375 Views)
06-05-2015 4:53 PM
Quote from: jelv
If you there is power near the master socket a simple solution would be to put the modem in to the master and then run an Ethernet cable to the router - that can be up to 100M with absolutely no loss of performance.
http://linitx.com/product/rf-elements-passive-poe-injectorsplitter-set/13305 - I used this to get around the power by the master socket problem, seems to power my HG612 just fine
Message 20 of 20
(375 Views)
- « Previous
- 1
- 2
- Next »
