Am I in sync?
createdbydan
Am I in sync?
Hi guys,
If anyone from Plusnet can assist me..
I cant connect to my home PC via remote desktop, and my pc never crashes, well not yet at least, but I need to know if my line is in sync, seeing as you dont allow remote management on your routers.
Kind regards,
Dan
createdbydan
I am on a static IP too
Fixes: 162
Re: Am I in sync?
Hi Dan,
One Day, 14:23:4 (on going) - that's your current connection session.
 Chris Parr
 Plusnet Staff
createdbydan
Re: Am I in sync?
Hmn OK thanks, is there any traffic passing on the WAN?
May have to go home and have a look, but if you can confirm current traffic is passing from my flat mate, then ill be happy.
Thanks,
Dan
Fixes: 162
Re: Am I in sync?
I can't see live traffic unfortunately, however I can see that today there has been a few GB transferred so something is using the connection.
 Chris Parr
 Plusnet Staff
createdbydan
Re: Am I in sync?
Hi Chris,
OK thanks for your help,
Dan
