All in one box
- All in one box
All in one box
30-01-2015 3:05 PM
Can anyone recommend a all in one box to replace the Plusnet box and the open reach box?
All i need is Gigabits Ethernet and Wifi A/C (due to the size of the house.
Message 1 of 6
(1,412 Views)
5 REPLIES 5
Re: All in one box
30-01-2015 4:11 PM
this is a good start point http://forum.kitz.co.uk/index.php?topic=14436.0
Message 2 of 6
(958 Views)
Re: All in one box
30-01-2015 5:08 PM
Hub 5 seems to be best way to go. I picked one up new on here for 38 after quite a bit of reading and looking at more expensive stuff. Easy to setup and get working and so far seems fast and reliable
Message 3 of 6
(958 Views)
Re: All in one box
30-01-2015 5:19 PM
Does anyone know if you can get decent VDSL stats from the HH5?
For example, number of errors, noise margin, line loss etc. Basically information that would be useful in diagnosing problems.
I have also read of numerous complaints about wi-fi dropouts on the HH5 but then I also hear of people that love it and have no complaints!
Message 4 of 6
(958 Views)
Re: All in one box
30-01-2015 5:25 PM
@jafreer
Each to their own.
But I believe the stats that are available are very basic just the sync speed!
Each to their own.
Message 5 of 6
(958 Views)
Re: All in one box
30-01-2015 9:30 PM
Thanks Joshua,
And do you find the wi-fi stable and reliable?
Thanks,
Thanks,
Message 6 of 6
(958 Views)
