All in one box
Cecemf
All in one box
Can anyone recommend a all in one box to replace the Plusnet box and the open reach box?
All i need is Gigabits Ethernet and Wifi A/C (due to the size of the house.
Fixes: 62
Re: All in one box
Psalliss
Re: All in one box
Hub 5 seems to be best way to go. I picked one up new on here for 38 after quite a bit of reading and looking at more expensive stuff. Easy to setup and get working and so far seems fast and reliable
jafreer
Re: All in one box
Does anyone know if you can get decent VDSL stats from the HH5?
For example, number of errors, noise margin, line loss etc. Basically information that would be useful in diagnosing problems.
I have also read of numerous complaints about wi-fi dropouts on the HH5 but then I also hear of people that love it and have no complaints!
Joshc
Re: All in one box
@jafreer
Each to their own.
But I believe the stats that are available are very basic just the sync speed!
Undecided
jafreer
Re: All in one box
Thanks Joshua,
And do you find the wi-fi stable and reliable?
Thanks,
